Up to 20% off select tools
Bosch Washing Machine Maxx 7 Disassembly
Views: 6K
View statistics:
Past 24 Hours:
12
Past 7 Days:
68
Past 30 Days:
238
All Time:
5,992
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
      • Get some big bucket
      • It would be recommended to wear glows during this repair
      • Get some bringt flashlight (just in case)
      Ask FixBot
      • Make sure that you unplugged the washing machine from the mains or otherwise there's a risk of getting electrocuted!
      • Close the water inlet
      • Make sure that your flashlight is working
      Ask FixBot
      • If the problem is still appearing, then take your flashlight and take the look on the pump which is located in the same hole, where you drained all the water. Sometimes there will be some hair or unwanted objects which prevent the pump from spinning
      • Make sure that the pump doesn't have any unwanted objects
      Ask FixBot
      • Optional you can check if the water pump is working without any problems. Sometimes it can happen that the system doesn't detect the failure of this pump and it gets burned. The attend of repairing the pump by yourself is not really recommend.
      • Here is a link which shows how to replace the water pump https://youtube.com/watch?v=ReWLHVFtXmY#
      Ask FixBot
Author
with
Michal S.
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 68
Past 30 Days: 238
All Time: 5,992
