Introduction
The dispenser drawer, also called the detergent drawer, holds washing powder, detergent, and fabric conditioner before they enter the wash. Over time, residue can build up into residue, grime, and mold. Remove the drawer to give it a thorough clean and wipe the dispenser cavity. This guide was written for the Bosch Serie 4 VarioPerfect washing machine and also applies to Siemens washing machines with a similar release-button drawer design.
Step 2 Remove the dispenser drawer
Find the dispenser drawer on the left side of the front panel.
Pull the drawer straight out until it stops.
Press the release button down firmly to lower the retaining clip.
Keep the button pressed and pull the drawer completely out of the machine.
Step 3 Clean the drawer shell
Rinse the drawer under hot water.
Use an brush to scrub away grime, dirt, mold, and washing powder residue.
Step 4 Clean the removable inserts
Lift out the measuring level if the drawer has one fitted.
Lift out the catch in the middle of the drawer.
Rinse the removable pieces and the drawer under a hot tap.
Use the brush to scrub the exposed areas where dirt and mold collect.
Step 5 Clean the dispenser cavity
Wipe inside the dispenser cavity with a non-scratch damp cloth while the drawer is removed.
Clean only the reachable surfaces, and don't force the cloth down into the opening.
Step 6 Refit the dispenser drawer
Line up the dispenser drawer with its runners.
Push the drawer in slowly until the release clip reaches the front edge.
Press the release button down again so the clip tucks underneath.
Push the drawer home until it closes fully.
The dispenser drawer should slide smoothly and sit flush when fully installed. Repair didn't go as planned? Ask our Answers community for help.
