Introduction
In this guide, I'll show you how to replace the vacuum cleaner's motor.
This vacuum cleaner has the exact model designation: BSGL5ZOO2/10
Remove residue bag G8.
Remove HEPA high efficiency hygiene filter 579496 VZ154HFB
Remove motor protection filter 578863 VZ01MSF
Use the spudger to lever the start button upwards from the front and remove it.
Lift the top of the housing from the handle side
Remove the top of the housing towards the rear.
Remove motor cover towards the back.
Carefully remove the circuit board from the guides of the cable drum.
The motor is now accessible.
Removing the Motor
Disconnect the cables / terminals from the motor.
Dispose of the motor (scrap metal).
Insert the protective fleece the right way around and with the cutouts properly aligned.
Unpack the new motor.
Checking the Fit of the Blower Seal
Insert the rubber mounts into the round cutouts.
Press the rubber mounts and the blower seal firmly into place.
Place and insert the motor with the rubber mount into the guide.
"Check that the motor is seated properly in the mount and in the housing.
Guide the cables through the cutouts in the fleece.
Firmly push the cables / spade connectors onto the terminals (there is no fixed assignment of the poles).
Release the rotary dial's board from the holder (pull back the clip).
Place the control board on the fleece, in front of the guide rails.
Place the motor cables into the cable guide of the motor cover.
Place the motor cables into the cable guide of the partition wall.
Move the motor cover downwards in the guides.
Slide the control board into the guides.
While doing so, make sure that the terminals of the cable reel are inserted cleanly into the rails of the control board.
Check the correct seating of the circuit board."
Place the cover on.
Clip the rotary dial's board into the holder.
Snap the cover into the holders by pressing it downwards.
If you feel confident enough, you can test the vacuum cleaner for the first time now.
Plug in the power plug.
Press the On/Off switch.
The motor should now work as usual.
To reassemble your device, follow the steps 1 to 6 in reverse order.
Special thanks to these translators:
100%
hainzy is helping us fix the world! Want to contribute?
Start translating ›
2 Guide Comments
Hallo, sehr toll gemachte Anleitung. Wirklich Respekt vor der Arbeit, die Bilder und deren Bearbeitung. Dickes Danke
