Bosch PS21 Gearbox (Clutch) Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
116
All Time:
4,656
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the gearbox in the Bosch PS21. If the clutch is not working, the gearbox will need to be replaced. Be sure to remove the battery before disassembling the device.
Tools
    1. Bosch PS21 Gearbox (Clutch) Replacement, Battery: step 1, image 1 of 1
      • Pinch the two release tabs on the sides of the battery, and slide the battery out.
      Ask FixBot
    1. Bosch PS21 Gearbox (Clutch) Replacement, Gearbox: step 2, image 1 of 2 Bosch PS21 Gearbox (Clutch) Replacement, Gearbox: step 2, image 2 of 2
      Tool used on this step:
      $3.99
      Buy
      • Locate the clip that binds the two halves of the outer casing together on the rear edge of the battery shaft. Remove the clip with the angled tweezers.
      Ask FixBot
    2. Bosch PS21 Gearbox (Clutch) Replacement: step 3, image 1 of 1
      • Locate the eight 5.5 mm screws on the upwards facing side of the drill.
      • Remove each screw using the T8 Torx screwdriver and place them together in a safe place.
      Ask FixBot
    3. Bosch PS21 Gearbox (Clutch) Replacement: step 4, image 1 of 2 Bosch PS21 Gearbox (Clutch) Replacement: step 4, image 2 of 2
      • Remove the upper portion of the case from the outer portion of the case using a metal spudger.
      Ask FixBot
    4. Bosch PS21 Gearbox (Clutch) Replacement: step 5, image 1 of 2 Bosch PS21 Gearbox (Clutch) Replacement: step 5, image 2 of 2
      • Dislodge the motor assembly from the casing.
      • Remove the gearbox from the motor assembly.
      Ask FixBot
Getsemani Gonzalez
321 Reputation
2 Guides authored
IUPUI, Team 1-2, Harley Spring 2016 Member of IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 116
All Time: 4,656
