Bosch MFQ 36440 Disassembly
    1. Bosch MFQ 36440 Disassembly, Remove screws: step 1, image 1 of 1
      • Remove 2x Torx screws (size 10) on the front
      Ask FixBot
    2. Bosch MFQ 36440 Disassembly, Remove the grey front cover: step 2, image 1 of 2 Bosch MFQ 36440 Disassembly, Remove the grey front cover: step 2, image 2 of 2
      • Remove the front cover
      • Gently push downwards the cover, then pull it through the holes
      • Once it is detached at the top, slide the entire gray cover down
      Ask FixBot
    3. Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: step 3, image 1 of 3 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: step 3, image 2 of 3 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: step 3, image 3 of 3
      • The first step is somewhat tricky. Use a long screwdriver to release the first part at the top.
      • Continue your way all around the case.
      • The clip on top front is tricky a long and thin flat screwdriver is needed
      • The clip on very top is impossible to release you need to pry the two half’s carefully apart until the top releases
      Ask FixBot
    4. Bosch MFQ 36440 Disassembly, Assembly: step 4, image 1 of 2 Bosch MFQ 36440 Disassembly, Assembly: step 4, image 2 of 2
      • Prop everything back into the half without the clips
      • Take care about the safety cam to be aligned in the cover
      Ask FixBot
8 other people completed this guide.
Stanky
1,385 Reputation
6 Guides authored
2 Guide Comments
Hey, so what does “Continue your way all around the case” mean? I got the one clip open which you pictured, and then I got the case open just a tiny bit more, but now I’m stuck.
Could someone perhaps detail the last steps more? :(
Carsten Hagemann - Reply Share
When you put it together again use the side with the cable “channels”, it is way easier than with the other side.
Tobias Vdb - Reply Share
Past 24 Hours: 5
Past 7 Days: 39
Past 30 Days: 175
All Time: 11,694
