Bosch IXO (2 Gen) Battery Replacement
    1. Bosch IXO (2 Gen) Battery Replacement, Unscrew screws: step 1, image 1 of 1
      • Loosen 4 screws size Torx T10. The screw size is identical for all four screws.
      • All four screws are the same length.
      Ask FixBot
    2. Bosch IXO (2 Gen) Battery Replacement, Detaching the type plate: step 2, image 1 of 3 Bosch IXO (2 Gen) Battery Replacement, Detaching the type plate: step 2, image 2 of 3 Bosch IXO (2 Gen) Battery Replacement, Detaching the type plate: step 2, image 3 of 3
      • Loosen the nameplate on the bottom of the screwdriver and set it aside so that the right housing part can be removed in the next step.
      Ask FixBot
    3. Bosch IXO (2 Gen) Battery Replacement, Open housing: step 3, image 1 of 2 Bosch IXO (2 Gen) Battery Replacement, Open housing: step 3, image 2 of 2
      • The housing halves now lie loosely on top of each other. Lift the right housing half upwards and set it aside.
      • It may be that the two halves of the case stick together quite strongly due to the gasket in between. Then shake it delicately and pull vigorously. :)
      Ask FixBot
    4. Bosch IXO (2 Gen) Battery Replacement, Locate battery: step 4, image 1 of 2 Bosch IXO (2 Gen) Battery Replacement, Locate battery: step 4, image 2 of 2
      • The green battery can be found in the red border.
      • The battery is labeled with: INR18650-13P SAMSUNG SDI 076
      • You can find it for example at Amazon or eBay, if you search for "Samsung 18650 13P solder tag
      Ask FixBot
    5. Bosch IXO (2 Gen) Battery Replacement, De-Soldering the battery: step 5, image 1 of 2 Bosch IXO (2 Gen) Battery Replacement, De-Soldering the battery: step 5, image 2 of 2
      • Heat the cables at both pole ends with a soldering iron and detach them.
      • In this tutorial, you will learn how to solder and desolder.
      • Please dispose of the battery properly at local disposal points.
      Ask FixBot
    6. Bosch IXO (2 Gen) Battery Replacement, Soldering of the new battery: step 6, image 1 of 1
      • Connect the side of the new battery with the white ring (positive pole +) to the red cable. Solder the blue cable to the other side (without the white ring).
      Ask FixBot
To reassemble the device, follow the steps in reverse order
21 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
BenZ78
21,242 Reputation
3 Guides authored
8 Guide Comments
Danke für die glasklaren Anweisungen!
FRITZ WIDRIG - Reply Share
Sehr gerne, freut mich, dass es geklappt hat :-)
BenZ78 - Reply Share
Supe,r danke
Rainer - Reply Share
Is it okay to replace the battery with a new one that has a BMS (Battery Management System) on it? The BMS is in a form of small pcb strip, and that pcb is inside the protection jacket of the battery. TIA.
Leebid - Reply Share
Yes, just make sure the new battery has the same length as the once installed, and that the new battery can handle 18 amps of continuous discharge.
Andrew S - Reply Share
Past 24 Hours: 24
Past 7 Days: 106
Past 30 Days: 383
All Time: 17,259
