Up to 20% off select tools
Bosch Error Code 680
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
113
All Time:
1,445
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Problem:
Error is not listed in the manual documentation.
Bosch Error Code 680 means, that the power button of the akku is constantly pressed.
The problem could be a small mechanical issue that I will discuss here.
Good luck with yours!
Bodo
Video Overview
    1. Bosch Error Code 680, Remove the plates and clean everything: step 1, image 1 of 1
      • Clean everything.
      • Remove the two plates with the 4 allen screws.
      Ask FixBot
    2. Bosch Error Code 680, Add a spacer on the akku: step 2, image 1 of 1
      • I needed to add a little spacer direct on the akku. Because the allen screws created too much force on the akku power button.
      Ask FixBot
    3. Bosch Error Code 680, Adjust the plate on the akku: step 3, image 1 of 1
      • Adjust the plate on the akku like this. Otherwise the akku could stuck when you try to mount or remove it from the bike.
      • Hint: If you loose the allen screw thread nubsis. look for the little white wholes in the akku that has scratched the black colour before. Then start with two screws and move till you catch the next one. Use a flashlight to find it.
      Ask FixBot
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Author
with
felusch
131 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 113
All Time: 1,445
