Bosch Dishwasher Spray Arm Cleaning
Video Guide
This guide was transcribed from a YouTube video.
    • Make sure the dishwasher is off, empty, and cool before you work inside the tub.
    • Turn off power at the wall switch or circuit breaker if the controls could be pressed while you work.
    • Open the door fully and slide the lower basket out of the dishwasher.
    Ask FixBot
    • Grip the lower spray arm near the center hub.
    • Lift the spray arm straight up until it pops out of its mount.
    • Set the spray arm where the holes are easy to inspect.
    Ask FixBot
    • Support the upper spray arm with one hand.
    • Turn the small locking nut counterclockwise about 25 degrees as you face it.
    • Pull the spray arm downward to remove it.
    • The locking nut only needs a short turn, not a full rotation.
    Ask FixBot
    • Use a wooden toothpick to clear food debris or mold from each spray hole.
    • Clean the holes on both sides of the upper spray arm.
    • Repeat the same cleaning on the lower spray arm.
    • Don't use a metal pick, because it can enlarge or damage the spray holes.
    Ask FixBot
    • Use hot water carefully to avoid scalding your hands.
    • Hold a spray arm under hot running water.
    • Direct the water into the funnel-shaped opening in the center of the spray arm.
    • Watch for water flowing freely from all of the spray holes.
    • Repeat the hot-water rinse for the other spray arm.
    • If a hole doesn't flow well, clear it again with the wooden toothpick and rinse it again.
    Ask FixBot
    • Slide the central nut out of the upper spray arm.
    • Rinse the nut under hot running water until it is clean.
    • Slide the nut back into the upper spray arm in the same orientation.
    • Make sure the nut is seated before fitting the spray arm back into the dishwasher.
    Ask FixBot
    • Align the lower spray arm with its mount in the bottom of the tub.
    • Press the spray arm downward until it pops into place.
    • Spin the spray arm by hand to check that it turns freely.
    • If it doesn't spin freely, lift it out, check for leftover debris, and press it into place again.
    Ask FixBot
    • Push the upper spray arm up into its mounting hole.
    • Turn the locking nut clockwise about 25 degrees as you face it until it locks into place.
    • Spin the upper spray arm by hand to check that it turns freely.
    • If the nut doesn't lock, lower the arm, align it with the hole, and try the 25-degree turn again.
    Ask FixBot
    • Slide the lower basket back into the dishwasher.
    • Check that the basket doesn't interfere with the lower spray arm.
    • Clean both spray arms twice a year to keep water spraying around the dishwasher properly.
    • If dishes still don't clean well, recheck that both spray arms spin freely and that all spray holes flow freely.
    Ask FixBot
Before you run a wash cycle, make sure both spray arms are fully seated and spin freely. Repeat this cleaning every six months, or anytime the spray holes look blocked. Repair didn't go as planned? Ask our Answers community for help.
eCuration
476,944 Reputation
385 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 144
All Time: 254
