Introduction
Use this guide to replace the door latch assembly in a Bosch dishwasher. The door latch keeps the door closed, helps maintain the door seal, and signals to the dishwasher that the door is shut. If the latch is broken, the door may not stay closed, the cycle may stop mid-wash, or the dishwasher may act as if the door opened. Before you begin, turn off the dishwasher's circuit breaker or unplug the power cord. This guide was written using a Bosch SHE3AR55UC dishwasher and Bosch door latch assembly part number 00630628, but your model may vary slightly.
Step 1 Disconnect the power
If the dishwasher isn't on its own breaker, unplug it from under the sink or behind the dishwasher.
Step 2 Remove the countertop mounting screws
Open the door and locate the two mounting brackets under the front edge of the countertop.
Use a Phillips screwdriver to remove the two screws holding the brackets to the countertop.
Close the dishwasher door.
Step 3 Pull the dishwasher forward
Grip both sides of the dishwasher and gently wobble it forward.
Pull the dishwasher out only far enough to expose the latch assembly on top, about 4 inches from under the countertop.
Step 4 Remove the latch cover plate
Locate the latch assembly on the top front edge of the dishwasher, under the steel cover plate.
Use a T20 Torx screwdriver to remove the four screws securing the steel cover plate.
Lift off the steel cover plate and set it aside with its screws.
Step 5 Remove the old latch assembly
Use a T20 Torx screwdriver to remove the screw holding the latch assembly.
Lift the latch assembly up and slide it sideways out of its mounting slot.
Step 6 Check the latch lever
Inspect the old latch for the small lever on the side of the assembly.
Compare the old latch with the replacement door latch assembly.
The replacement latch should have a lever that resets the latch when the door closes.
Replace the latch if the lever is snapped off or the latch won't reset.
Step 7 Install the replacement latch
Insert the replacement latch assembly into the mounting slot at a slight sideways angle.
Press the latch assembly down into place.
Make sure the latch sits flat and lines up with its screw hole.
Step 8 Test the latch before reassembly
Close and open the dishwasher door a few times to check the new latch.
Confirm that the door latches every time.
Step 9 Reinstall the latch cover plate
Use a T20 Torx screwdriver to reinstall the screw holding the latch assembly.
Set the steel cover plate over the latch assembly.
Use a T20 Torx screwdriver to reinstall the four cover plate screws.
Step 10 Slide the dishwasher back into place
Gently shift the dishwasher back into the cabinet opening.
Step 11 Secure the dishwasher
Align the mounting brackets with their holes under the countertop.
Use a Phillips screwdriver to reinstall the two mounting screws.
Tighten the screws until the brackets are secure.
Step 12 Restore power and test the door
Close the dishwasher door and confirm that it latches properly.
Turn the breaker on or plug the dishwasher back in.
Run a wash cycle to confirm the door stays latched and the cycle doesn't stop as if the door opened.
The dishwasher door should now latch securely and stay closed during a wash cycle. Repair didn't go as planned? Ask our Answers community for help.
