Bosch CTPM Tassimo fix pump error
Views: 4.2K
View statistics:
Past 24 Hours:
19
Past 7 Days:
108
Past 30 Days:
411
All Time:
4,222
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
These instructions show you how to disassemble or open the coffee machine. The housing parts are not easy to remove—it takes a little patience to find the right places to unclip them with a screwdriver.
    1. Bosch CTPM Tassimo fix pump error, Open the housing (top): step 1, image 1 of 3 Bosch CTPM Tassimo fix pump error, Open the housing (top): step 1, image 2 of 3 Bosch CTPM Tassimo fix pump error, Open the housing (top): step 1, image 3 of 3
      • Flip up the water tank cover and unclip it.
      • First lift the top cover at the back, as shown in the photo. The screwdriver can be inserted at the yellow markings.
      • Then slide the cover backwards. When open, the hooks are clearly visible. You can also see the side wall fastenings from the inside. Use a flashlight to illuminate the interior to better understand the side wall fastenings.
      Ask FixBot
    2. Bosch CTPM Tassimo fix pump error, Open the housing (side panels): step 2, image 1 of 2 Bosch CTPM Tassimo fix pump error, Open the housing (side panels): step 2, image 2 of 2
      • There are small recesses at the markings that indicate where to insert the screwdriver. If you look at the side panels from above, you can see how they are attached.
      • The two clips must be pushed aside while simultaneously sliding the side panel backwards.
      Ask FixBot
    3. Bosch CTPM Tassimo fix pump error, Remove the back panel: step 3, image 1 of 2 Bosch CTPM Tassimo fix pump error, Remove the back panel: step 3, image 2 of 2
      • Using a screwdriver or your finger, press against the clips from below and gently fold the back panel backwards.
      • Open the other clips at the bottom of the back panel with a screwdriver.
      Ask FixBot
    4. Bosch CTPM Tassimo fix pump error, Internal components: step 4, image 1 of 3 Bosch CTPM Tassimo fix pump error, Internal components: step 4, image 2 of 3 Bosch CTPM Tassimo fix pump error, Internal components: step 4, image 3 of 3
      • The heating element, this can be checked by measuring the resistance.
      • The upper temperature sensor.
      • The lower temperature sensor.
      • The reed / magnetic switch at the back panel for the water level. And the E410 water pump.
      Ask FixBot
    5. Bosch CTPM Tassimo fix pump error, Internal components: step 5, image 1 of 3 Bosch CTPM Tassimo fix pump error, Internal components: step 5, image 2 of 3 Bosch CTPM Tassimo fix pump error, Internal components: step 5, image 3 of 3
      • Temperature safety switch (reversible) and temperature fuse as a double component.
      • Ribbon cable to the coffee capsule scanner.
      • Sensor connectors (water level, temperature top, temperature bottom, ???)
      • Capsule replacement plate for cleaning process. The barcode is read out in the brew element. Without a capsule or the plate the machine will not operate.
      • Cut the cable ties and remove the hose. Insert a toothpick into the outlet of the pump from below – this will release the check ball. This was stuck or blocked by limescale and prevented the water from flowing.
      • If you want to check whether the heating element is so calcified that water can no longer flow through it, this hose must also be opened – as must the hose on the other side of the heating element.
      Ask FixBot
work all steps in reverse order to reassemble the device
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Andreas Reheis
4,188 Reputation
27 Guides authored
DerToaster Member of DerToaster
Local Repair Groups
6 Members
420 Guides authored
2 Guide Comments
Is there a video somewhere to show me how to get the side panel off?
Geoff Medwid - Reply Share
Hi Geoff,
I have no Video. But take a look at the description in step 2.
Andreas Reheis - Reply Share
Past 24 Hours: 19
Past 7 Days: 108
Past 30 Days: 411
All Time: 4,222
