Bosch 3727DEVS Power Cord Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
112
All Time:
989
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Purchase a new Power Cord. The sander should be unplugged from any power sources. Make sure you organize the removed screws, so you can reinstall them in the correct location.
Parts
Tools
    1. Bosch 3727DEVS Power Cord  Replacement, Power Cord: step 1, image 1 of 3 Bosch 3727DEVS Power Cord  Replacement, Power Cord: step 1, image 2 of 3 Bosch 3727DEVS Power Cord  Replacement, Power Cord: step 1, image 3 of 3
      • Ensure that the power chord is not plugged into an outlet.
      • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
      • Lift the top cover off the sander.
      Ask FixBot
    2. Bosch 3727DEVS Power Cord  Replacement: step 2, image 1 of 3 Bosch 3727DEVS Power Cord  Replacement: step 2, image 2 of 3 Bosch 3727DEVS Power Cord  Replacement: step 2, image 3 of 3
      • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
      • Lift cable clip and cord from motor housing.
      Ask FixBot
    3. Bosch 3727DEVS Power Cord  Replacement: step 3, image 1 of 3 Bosch 3727DEVS Power Cord  Replacement: step 3, image 2 of 3 Bosch 3727DEVS Power Cord  Replacement: step 3, image 3 of 3
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 112
All Time: 989
