Bosch 3727DEVS On/Off Switch Replacement
    1. Bosch 3727DEVS On/Off Switch Replacement, On/Off Switch: step 1, image 1 of 3 Bosch 3727DEVS On/Off Switch Replacement, On/Off Switch: step 1, image 2 of 3 Bosch 3727DEVS On/Off Switch Replacement, On/Off Switch: step 1, image 3 of 3
      • Ensure that the power chord is not plugged into an outlet.
      • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
      • Lift the top cover off the sander.
      Ask FixBot
    2. Bosch 3727DEVS On/Off Switch Replacement: step 2, image 1 of 3 Bosch 3727DEVS On/Off Switch Replacement: step 2, image 2 of 3 Bosch 3727DEVS On/Off Switch Replacement: step 2, image 3 of 3
      • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
      • Lift the cable clip and cord from motor housing.
      Ask FixBot
    3. Bosch 3727DEVS On/Off Switch Replacement: step 3, image 1 of 3 Bosch 3727DEVS On/Off Switch Replacement: step 3, image 2 of 3 Bosch 3727DEVS On/Off Switch Replacement: step 3, image 3 of 3
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
      Ask FixBot
    4. Bosch 3727DEVS On/Off Switch Replacement: step 4, image 1 of 3 Bosch 3727DEVS On/Off Switch Replacement: step 4, image 2 of 3 Bosch 3727DEVS On/Off Switch Replacement: step 4, image 3 of 3
      • Remove the gray and purple wires by pulling on the wire terminals.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 30
Past 30 Days: 92
All Time: 874
