Bosch 3727DEVS Governor Replacement
    1. Bosch 3727DEVS Governor Replacement, Governor: step 1, image 1 of 3 Bosch 3727DEVS Governor Replacement, Governor: step 1, image 2 of 3 Bosch 3727DEVS Governor Replacement, Governor: step 1, image 3 of 3
      • Ensure that the power chord is not plugged into an outlet.
      • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
      • Lift the top off of the sander.
      Ask FixBot
    2. Bosch 3727DEVS Governor Replacement: step 2, image 1 of 3 Bosch 3727DEVS Governor Replacement: step 2, image 2 of 3 Bosch 3727DEVS Governor Replacement: step 2, image 3 of 3
      • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
      • Lift the cable clip and cord from motor housing.
      Ask FixBot
    3. Bosch 3727DEVS Governor Replacement: step 3, image 1 of 1
      • Lift the On/Off switch out of the device
      • Remove the gray and purple wires
      Ask FixBot
    4. Bosch 3727DEVS Governor Replacement: step 4, image 1 of 2 Bosch 3727DEVS Governor Replacement: step 4, image 2 of 2
      • Remove the gray, brown, and clear wires by pulling on the wire terminals.
      • Lift the Governor out of the housing.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 37
All Time: 963
