Up to 20% off select tools
Boot Zipper Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
24
Past 7 Days:
160
Past 30 Days:
659
All Time:
4,411
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 7 hours
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide shows the process of replacing a broken boot zipper.
Broken zippers are a common issue found on daily clothing, especially boots. Over time, zippers can wear out due to regular use. The teeth may become worn, or the slider may lose its grip, leading to malfunction. Sometimes, forcing the zipper when it’s stuck or overloading the boot can also cause the zipper to break, for zippers are designed to handle a certain amount of stress, and exceeding this can lead to damage. Broken zippers lead to the boots seen as unusable and open up the possibility for it to be thrown away.
Therefore, addressing these issues promptly can help extend the life of your boots and prevent the need for more extensive repairs or replacements.
With this guide, we will show how to replace a boot zipper, saving the overall boot and lessening the waste of thrown-out clothing.
    1. Boot Zipper Replacement, Zipper: step 1, image 1 of 2 Boot Zipper Replacement, Zipper: step 1, image 2 of 2
      • Using a seam ripper, carefully remove the stitching at the top of the boot on either side of the zipper.
      • Only remove enough to free the zipper, about ¾ of an inch.
      Ask FixBot
    2. Boot Zipper Replacement: step 2, image 1 of 3 Boot Zipper Replacement: step 2, image 2 of 3 Boot Zipper Replacement: step 2, image 3 of 3
      • Remove the stitching on the heel side of the zipper.
      • The stitches on the heel side connect four layers of material: the lining, the zipper underlay, the zipper, and the outer leather.
      • Work between the leather and the zipper by pulling apart the leather and zipper and inserting the seam ripper into the gap.
      Ask FixBot
    3. Boot Zipper Replacement: step 3, image 1 of 2 Boot Zipper Replacement: step 3, image 2 of 2
      • Remove the stitching on the toe side of the zipper.
      • The stitches on the toe side connect three layers of material: the lining, the zipper, and the outer leather.
      • Set aside the original zipper.
      Ask FixBot
    4. Boot Zipper Replacement: step 4, image 1 of 1
      • Remove any leftover thread.
      Ask FixBot
    5. Boot Zipper Replacement: step 5, image 1 of 2 Boot Zipper Replacement: step 5, image 2 of 2
      • Measure your zipper against the boot.
      • Use a pin to mark how long it should be.
      Ask FixBot
    6. Boot Zipper Replacement: step 6, image 1 of 1
      • If your zipper is too long, trim it about an inch below your pin.
      Ask FixBot
    7. Boot Zipper Replacement: step 7, image 1 of 2 Boot Zipper Replacement: step 7, image 2 of 2
      • Fold down the excess fabric at the top of the zipper twice to create a right angle.
      Ask FixBot
    8. Boot Zipper Replacement: step 8, image 1 of 3 Boot Zipper Replacement: step 8, image 2 of 3 Boot Zipper Replacement: step 8, image 3 of 3
      • Stitch in place.
      • Use pliers if the fabric is too thick to push the needle through easily.
      Ask FixBot
    9. Boot Zipper Replacement: step 9, image 1 of 2 Boot Zipper Replacement: step 9, image 2 of 2
      • Pin your new zipper to the outer leather on the heel side.
      • Be careful to put your pins through the existing holes in the leather to avoid damaging the leather further.
      Ask FixBot
    10. Boot Zipper Replacement: step 10, image 1 of 1
      • Using a backstitch, sew the zipper to the leather along the inner row of stitching.
      • Be careful to put your needle through the existing holes in the leather to avoid damaging the leather further.
      Ask FixBot
    11. Boot Zipper Replacement: step 11, image 1 of 2 Boot Zipper Replacement: step 11, image 2 of 2
      • Repeat steps 8 and 9 for the toe side of the zipper.
      Ask FixBot
    12. Boot Zipper Replacement: step 12, image 1 of 2 Boot Zipper Replacement: step 12, image 2 of 2
      • Pin the lining to the zipper and leather on the toe side.
      Ask FixBot
    13. Boot Zipper Replacement: step 13, image 1 of 2 Boot Zipper Replacement: step 13, image 2 of 2
      • Using a backstitch, sew the lining into place along the outer row of stitching.
      Ask FixBot
    14. Boot Zipper Replacement: step 14, image 1 of 2 Boot Zipper Replacement: step 14, image 2 of 2
      • Pin the lining and zipper underlay to the zipper and outer leather on the heel side.
      Ask FixBot
    15. Boot Zipper Replacement: step 15, image 1 of 1
      • Using a backstitch, sew the lining and zipper underlay into place along the outer row of stitching.
      Ask FixBot
    16. Boot Zipper Replacement: step 16, image 1 of 2 Boot Zipper Replacement: step 16, image 2 of 2
      • This should be the final outcome after you repair the boot.
      Ask FixBot
Finish Line
Author
with
Alex
258 Reputation
1 Guide authored
UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 4-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G2
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 24
Past 7 Days: 160
Past 30 Days: 659
All Time: 4,411
