Up to 20% off select tools
Boot Media creation (Multi image) - Ventoy
View statistics:
Past 24 Hours:
9
Past 7 Days:
58
Past 30 Days:
329
All Time:
495
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Author's Note (11/18/2026): I tried to avoid a size requirement change, but it was unavoidable :-(. Most ISOs are built around one architecture (ex: Linux amd64 (64-bit), x86_64 (32/64-bit)/i686(Legacy 32-bit) and aarch64 (ARM64). As a result, drive requirements had to increase accordingly. Drive capacity minimums with this guide are a moving target; minimum sizes will change as needed (noted when if possible).
System, Drive Requirements & Critical Warnings
  • Storage Capacity: A portable (DIY or prebuilt) SSD or USB flash drive:
    • 64GB: Best for single-architecture drives. These fill rapidly with multi-arch media; split your x86 and ARM64 ISOs over two dedicated drives. Note: With utility distros like Parted Magic adopting ARM64, 64GB is skating on thin ice nearing retirement into the "low capacity" group (8-32GB)— I will hold out as long as I can but keep this in mind as it will become worse over time.
    • 128GB: Ideal for low-rotation multi-architecture storage and moderate ISO collections on a single drive. Not recommended for diverse multi-arch drives; fixed use drives are fine.
    • 256GB+: Best for master toolkits and long-term multi-arch storage (256GB SSDs vs flash drives: ~$25–30 for USB flash, ~$50–70 for a portable SSD). Portable SSDs offer true NVMe or SATA 600Mbps speeds for a modest price increase. DIY SSDs come in around a similar price point. Any good quality enclosure will work if you are building your own portable SSD.
    • 32GB and smaller (32GB, 16GB, 8GB): Not recommended for general use, but serviceable for fixed-purpose drives (e.g., legacy ISOs) or specialized use cases (e.g., 32-bit CPU w/o PAE). They hold only a few images and have major capacity downsides. Later 8–16GB drives made when 32GB+ became common are not recommended as these are low-quality binned drives.
  • Data Loss: Installing Ventoy will completely format and erase the target USB flash drive. Ensure any necessary data is backed up to another location before proceeding, or use a drive you can safely format.
  • Drive Selection & Permissions: Ventoy requires administrator privileges to run, so you may need admin credentials if you are using a standard user account. Before writing to the drive, verify that you have selected the correct target flash drive during setup to avoid accidentally erasing the wrong drive or your computer's primary storage. For absolute safety, temporarily disconnect any other external drives you do not need for the process.
  • macOS Support: macOS is not supported by Ventoy.
  • Linux Support: Linux is fully supported. While some distributions allow you to run the GTK3 file graphically with your admin password, the terminal method remains universal.
    1. Boot Media creation (Multi image) - Ventoy, Download Ventoy: step 1, image 1 of 1
      • For times sake I pre-downloaded Ventoy - if you need to download it, go to the Downloads tab and pick the correct version for your system (Windows or Linux). NOTE: Linux users will use the same steps but the executable must be started from the Terminal - drag the file to the Terminal and you will be able to run it on many distros.
      • Go to the Ventoy website and download Ventoy from the Downloads tab - select the right version for what you need. Once it is downloaded, put the file in the place your ISOs will be placed. Both versions need to be extracted to be run.
      Ask FixBot
    2. Boot Media creation (Multi image) - Ventoy, USB drive insertion: step 2, image 1 of 1
      • IMPORTANT: THE USB DRIVE YOU USE WILL BE ERASED! Make sure the drive is new, or you do not need the data on the drive. IF YOU NEED THE DATA MOVE IT TO ANOTHER DRIVE FIRST!
      • Plug the USB drive into your computer and have it ready - the drive can be corrupted, empty or blanked out to a RAW state without issues as the tool formats the drive.
      Ask FixBot
    3. Boot Media creation (Multi image) - Ventoy, Install Ventoy: step 3, image 1 of 3 Boot Media creation (Multi image) - Ventoy, Install Ventoy: step 3, image 2 of 3 Boot Media creation (Multi image) - Ventoy, Install Ventoy: step 3, image 3 of 3
      • Note: Ventoy requires admin rights to run.
      • With the drive in the PC, open Ventoy2Disk. Once Ventoy is opened, you will see the target drive -- MAKE SURE THE CORRECT DRIVE IS SELECTED OR OTHER DRIVES ARE REMOVED to avoid erasing the wrong one!
      • Select the target flash drive and then make sure it is the right one -- the entire drive will be erased. Once you selected the right one, click Install.
      • Select Install and the tool will be loaded onto the flash drive. You will receive 2 warnings about formatting the drive. This is normal, click Yes on both.
      Ask FixBot
    4. Boot Media creation (Multi image) - Ventoy, Loading boot images: step 4, image 1 of 3 Boot Media creation (Multi image) - Ventoy, Loading boot images: step 4, image 2 of 3 Boot Media creation (Multi image) - Ventoy, Loading boot images: step 4, image 3 of 3
      • Once the drive is created, ISO placement is done by dragging the files to the drive named Ventoy. Copy the ISOs to the drive you will need for your drive.
      Ask FixBot
Nick
107,129 Reputation
73 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 58
Past 30 Days: 329
All Time: 495
