BolaButty X-GO C27-C Battery Replacement
  1. BolaButty X-GO C27-C Battery Replacement, Charging Port: step 1, image 1 of 3 BolaButty X-GO C27-C Battery Replacement, Charging Port: step 1, image 2 of 3 BolaButty X-GO C27-C Battery Replacement, Charging Port: step 1, image 3 of 3
    • Take an opening tool or pick and wedge it into the groove between the endcap and the main casing. Wiggle it back and forth.
    • Strike the speaker endcap firmly against a solid surface to pop the end caps off.
    • Removing the end caps requires a good amount of force. There is a realistic chance that you will damage your speaker or break the caps.
    Ask FixBot
  2. BolaButty X-GO C27-C Battery Replacement: step 2, image 1 of 2 BolaButty X-GO C27-C Battery Replacement: step 2, image 2 of 2
    • Wedge an opening tool or a pick under the speaker cover and work it back and forth to loosen it. Repeat for all four sides.
    • Remove the speaker cover.
    Ask FixBot
  3. BolaButty X-GO C27-C Battery Replacement: step 3, image 1 of 2 BolaButty X-GO C27-C Battery Replacement: step 3, image 2 of 2
    • Remove the eight 12 mm screws securing the driver housing using a Phillips #0 screwdriver.
    • Gently pull apart the two halves of the speaker.
    • Take care not to strain the cables.
    Ask FixBot
  4. BolaButty X-GO C27-C Battery Replacement: step 4, image 1 of 2 BolaButty X-GO C27-C Battery Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the three 10 mm screws securing the charging housing.
    • Separate the charging port from the battery.
    Ask FixBot
  5. BolaButty X-GO C27-C Battery Replacement: step 5, image 1 of 2 BolaButty X-GO C27-C Battery Replacement: step 5, image 2 of 2
    • Use a pair of tweezers to lift the black ZIF locking flap securing the ribbon attached to the charging port.
    • While pulling up on the latch, remove the ribbon.
    Ask FixBot
  6. BolaButty X-GO C27-C Battery Replacement, Battery: step 6, image 1 of 2 BolaButty X-GO C27-C Battery Replacement, Battery: step 6, image 2 of 2
    • Disconnect the battery connector from its motherboard port.
    Ask FixBot
  7. BolaButty X-GO C27-C Battery Replacement: step 7, image 1 of 2 BolaButty X-GO C27-C Battery Replacement: step 7, image 2 of 2
    • Use a spudger to lift the battery from the casing.
    • The battery is secured with some adhesive. If you have a difficult time removing it, use a hairdryer to lightly heat the adhesive.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 other people completed this guide.
jcate
572 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 130
All Time: 1,068
