Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓This replacement guide will demonstrate step-by-step how to replace a pulley cable in a BodyCraft XPress Pro home gym.
A worn or damaged cable can prevent the pulley system from running smoothly or even cause damage to other parts in the pulley system. You will know that the cable needs to be replaced if the equipment has choppy movement, makes grinding noises, or if the metal is exposed on the cable.
Replacing this part if it is damaged or worn out will greatly extend the lifespan of this equipment. When the cable is replaced, you will notice that the equipment moves smoothly and efficiently.
Tools
Use the ratchet to unscrew each of the 12.7 mm hex bolts from the outer case.
Remove the panels surrounding the weight stack.
