Up to 20% off select tools
Blue Yeti USB component replacement
Views: 5K
View statistics:
Past 24 Hours:
10
Past 7 Days:
54
Past 30 Days:
272
All Time:
4,969
Comments: 12
11 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Is your Blue Yeti is tired, the USB is sometimes capricious, or it simply turns on but is not recognized by the computer? Here is surely the solution to your problem.
    1. Blue Yeti USB component replacement, Retrieve parts and Item and Note 3 Screws on the bottom: step 1, image 1 of 3 Blue Yeti USB component replacement, Retrieve parts and Item and Note 3 Screws on the bottom: step 1, image 2 of 3 Blue Yeti USB component replacement, Retrieve parts and Item and Note 3 Screws on the bottom: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • First remove the Rubber inside the screwable mount area. This can easily be done with a small screw driver tip or Tweezers. From here you can remove the 3 screws using a #1 Phillips head.
      Ask FixBot
    2. Blue Yeti USB component replacement, Removal of the exterior buttons: step 2, image 1 of 1
      • The 4 exterior buttons can be removed with any force such as fingers or any form of pliers. I used my fingers to remove and pull the buttons from their button placement. You will notice there is a lot of give from the mesh and the body.
      Ask FixBot
    3. Blue Yeti USB component replacement, Remove the Main circuits from the housing: step 3, image 1 of 3 Blue Yeti USB component replacement, Remove the Main circuits from the housing: step 3, image 2 of 3 Blue Yeti USB component replacement, Remove the Main circuits from the housing: step 3, image 3 of 3
      • On this step, you can easily and carefully pull the entire mic mechanism from the protective housing. On the bottom you will see where the Audio port and USB port are if you need to replace them.
      Ask FixBot
    4. Blue Yeti USB component replacement, Removing the Mic condenser from the Mic Mesh: step 4, image 1 of 2 Blue Yeti USB component replacement, Removing the Mic condenser from the Mic Mesh: step 4, image 2 of 2
      • If you look toward the mesh and the circuits you will see that it is held by 4x #0 Phillips screws. Carefully remove these and the entire cap will come from the board. There are 3 sets of wires, 1 per condenser. You will notice that they are pointed sideways, making this microphone a side condenser, not a face-pointed one.
      Ask FixBot
    5. Blue Yeti USB component replacement, The Condensers: step 5, image 1 of 3 Blue Yeti USB component replacement, The Condensers: step 5, image 2 of 3 Blue Yeti USB component replacement, The Condensers: step 5, image 3 of 3
      • As seen in the picture, this Microphone cap comes with a internal foam guard to protect the three internal mic condensers. These point outward to the side of the mic making this mic more useful from the side and not pointed at the users itself.
      Ask FixBot
    6. Blue Yeti USB component replacement, Disconnecting the Mic Condensers: step 6, image 1 of 1
      • If you need to disconnect the microphone cap from the board, pay close attention to the connections.
      • There are 3 condenser, therefore 3 pairs of wires connect to the board, each with their own wire color (black & white, black & red and black & blue)
      • Pick a position from where to look at the board and take notes of the position of each connector. This is important, since it will directly affect the PATTERN MODES selected in the back side of the mic.
      Ask FixBot
    1. Blue Yeti USB component replacement, Failure check: step 7, image 1 of 1
      • Defective part to be replaced
      • Just test it with a multimeter in sound mode.
      • If the beep is continuous, the problem lies elsewhere.
      • If the multimeter does not beep, or jerks, the component should be changed.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Corbanizer is helping us fix the world! Want to contribute?
Start translating ›
Author
with
XKali
140 Reputation
1 Guide authored
1 Guide Comment
hey there, what is this part called. Dont know what to look for online to buy a new one.
Bla Blubb - Reply Share
Past 24 Hours: 10
Past 7 Days: 54
Past 30 Days: 272
All Time: 4,969
