Blu Studio Selfie Front Facing Camera Replacement
    1. Blu Studio Selfie Front Facing Camera Replacement, Rear Cover: step 1, image 1 of 1
      • Make sure your phone is powered off.
      • Turn the front of the phone away from you.
      • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
      Ask FixBot
    2. Blu Studio Selfie Front Facing Camera Replacement: step 2, image 1 of 1
      • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
      • Gently apply pressure until you feel the back case pop free of the phone.
      • Continue the previous two steps around the rest of the phone until the case is fully removed.
      Ask FixBot
    1. Blu Studio Selfie Front Facing Camera Replacement, Battery: step 3, image 1 of 2 Blu Studio Selfie Front Facing Camera Replacement, Battery: step 3, image 2 of 2
      • Identify the crevice at the bottom of the battery.
      • There should be enough space for you to fit your fingernail between the battery and the phone.
      • Gently lift the battery free of the phone.
      Ask FixBot
    1. Blu Studio Selfie Front Facing Camera Replacement, Midframe: step 4, image 1 of 1
      • Remove all the 4mm Phillips #000 screws from the midframe.
      Ask FixBot
    2. Blu Studio Selfie Front Facing Camera Replacement: step 5, image 1 of 1
      • Insert the spudger between the midframe and the display assembly.
      • Gently pry up the midframe.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    3. Blu Studio Selfie Front Facing Camera Replacement: step 6, image 1 of 1
      • Where the battery rested before, you will find a small clip that holds down the midframe.
      • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
      • Gently lift up on the clip until it comes free.
      • Remove the midframe from the phone.
      Ask FixBot
    1. Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: step 7, image 1 of 3 Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: step 7, image 2 of 3 Blu Studio Selfie Front Facing Camera Replacement, Front Facing Camera: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to lift the black tab on the ZIF connector and pull the ribbon cable out of place.
      • Using a pair of tweezers for assistance, remove the front facing camera from its case.
      Ask FixBot
3 other people completed this guide.
Stacy Kam
630 Reputation
5 Guides authored
USF Tampa, Team 10-1, Remmell Spring 2016 Member of USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 97
All Time: 965
