Blu Studio Selfie Battery Replacement
    1. Blu Studio Selfie Battery Replacement, Rear Cover: step 1, image 1 of 1
      • Make sure your phone is powered off.
      • Turn the front of the phone away from you.
      • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
      Ask FixBot
    2. Blu Studio Selfie Battery Replacement: step 2, image 1 of 1
      • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
      • Gently apply pressure until you feel the back case pop free of the phone.
      • Continue the previous two steps around the rest of the phone until the case is fully removed.
      Ask FixBot
    1. Blu Studio Selfie Battery Replacement, Battery: step 3, image 1 of 2 Blu Studio Selfie Battery Replacement, Battery: step 3, image 2 of 2
      • Identify the crevice at the bottom of the battery.
      • There should be enough space for you to fit your fingernail between the battery and the phone.
      • Gently lift the battery free of the phone.
      Ask FixBot
Stacy Kam
630 Reputation
5 Guides authored
USF Tampa, Team 10-1, Remmell Spring 2016 Member of USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 99
All Time: 1,735
