Blu Studio 5.5 S Screen Replacement
  1. Blu Studio 5.5 S Screen Replacement, Back Casing: step 1, image 1 of 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Screen Replacement, Applying Pressure: step 2, image 1 of 3 Blu Studio 5.5 S Screen Replacement, Applying Pressure: step 2, image 2 of 3 Blu Studio 5.5 S Screen Replacement, Applying Pressure: step 2, image 3 of 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Screen Replacement, Battery: step 3, image 1 of 3 Blu Studio 5.5 S Screen Replacement, Battery: step 3, image 2 of 3 Blu Studio 5.5 S Screen Replacement, Battery: step 3, image 3 of 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Screen Replacement, Midframe: step 4, image 1 of 3 Blu Studio 5.5 S Screen Replacement, Midframe: step 4, image 2 of 3 Blu Studio 5.5 S Screen Replacement, Midframe: step 4, image 3 of 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Screen Replacement, Aesthetic Bottom Case: step 5, image 1 of 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Screen Replacement: step 6, image 1 of 3 Blu Studio 5.5 S Screen Replacement: step 6, image 2 of 3 Blu Studio 5.5 S Screen Replacement: step 6, image 3 of 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Screen Replacement, Motherboard: step 7, image 1 of 3 Blu Studio 5.5 S Screen Replacement, Motherboard: step 7, image 2 of 3 Blu Studio 5.5 S Screen Replacement, Motherboard: step 7, image 3 of 3
    • Remove the three 7 mm screws using the Phillips #00 Screwdiver.
    • Disconnect motherboard plug connector near bottom right of battery using fingers to pull off the cap plug.
  8. Blu Studio 5.5 S Screen Replacement: step 8, image 1 of 3 Blu Studio 5.5 S Screen Replacement: step 8, image 2 of 3 Blu Studio 5.5 S Screen Replacement: step 8, image 3 of 3
    • Use the nylon spudger to lift the release tabs by carefully grabbing the tabs from the sides and lifting up.
    • Release the four ribbon wires from the motherboard.
  9. Blu Studio 5.5 S Screen Replacement: step 9, image 1 of 2 Blu Studio 5.5 S Screen Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to grip the bottom of the motherboard and lift up.
  10. Blu Studio 5.5 S Screen Replacement, Screen: step 10, image 1 of 2 Blu Studio 5.5 S Screen Replacement, Screen: step 10, image 2 of 2
    • Remove speaker circuit board from bottom of the phone by using a Spudger to gently lift up.
    • The speaker circuit board is attached with adhesive. Be careful not to break when removing.
    • Once this piece is removed, you can replace your part with the new screen and digitizer assembly.
Greg Cerabona
167 Reputation
1 Guide authored
IUPUI, Team S2-G2, Wilson Spring 2017 Member of IUPUI, Team S2-G2, Wilson Spring 2017
IUPUI-WILSON-S17S2G2
5 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,220
