Blu Studio 5.5 S Front Facing Camera Replacement
  1. Blu Studio 5.5 S Front Facing Camera Replacement, Back Casing: step 1, image 1 of 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: step 2, image 1 of 3 Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: step 2, image 2 of 3 Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: step 2, image 3 of 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Front Facing Camera Replacement, Battery: step 3, image 1 of 3 Blu Studio 5.5 S Front Facing Camera Replacement, Battery: step 3, image 2 of 3 Blu Studio 5.5 S Front Facing Camera Replacement, Battery: step 3, image 3 of 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: step 4, image 1 of 3 Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: step 4, image 2 of 3 Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: step 4, image 3 of 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Front Facing Camera Replacement, Aesthetic Bottom Case: step 5, image 1 of 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Front Facing Camera Replacement: step 6, image 1 of 3 Blu Studio 5.5 S Front Facing Camera Replacement: step 6, image 2 of 3 Blu Studio 5.5 S Front Facing Camera Replacement: step 6, image 3 of 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: step 7, image 1 of 2 Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: step 7, image 2 of 2
    • The frontward facing camera is located in the top left of the phone. It is connected to the motherboard by a ribbon connector, and a prong system.
    • Use a spudger to detach the front facing camera by flipping the orange tab on the top of the prong system.
    • Once the orange tab is up, pull out the orange ribbon wire.
  8. Blu Studio 5.5 S Front Facing Camera Replacement: step 8, image 1 of 2 Blu Studio 5.5 S Front Facing Camera Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to pick up the ribbon wire, and lift. The frontward facing camera will follow suit.
Cody Dyl
804 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Miles Fall 2014 Member of UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,754
