Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: step 1, image 1 of 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: step 2, image 1 of 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: step 2, image 2 of 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: step 2, image 3 of 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: step 3, image 1 of 3 Blu Studio 5.5 S Battery Replacement, Battery: step 3, image 2 of 3 Blu Studio 5.5 S Battery Replacement, Battery: step 3, image 3 of 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
7 other people completed this guide.
Cody Dyl
804 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Miles Fall 2014 Member of UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 6,382
