Blu Studio 5.5 Camera Replacement
  1. Blu Studio 5.5 Camera Replacement, Battery: step 1, image 1 of 1
    • Flip over your Studio 5.5 so the back is facing you.
    • Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
  2. Blu Studio 5.5 Camera Replacement: step 2, image 1 of 2 Blu Studio 5.5 Camera Replacement: step 2, image 2 of 2
    • Place your finger in the small groove beneath the battery.
    • Push the battery toward the top of the phone and lift it out.
  3. Blu Studio 5.5 Camera Replacement, Camera: step 3, image 1 of 1
    • Begin by removing the 12 3.5mm screws along the back of the device.
    • 1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
  4. Blu Studio 5.5 Camera Replacement: step 4, image 1 of 2 Blu Studio 5.5 Camera Replacement: step 4, image 2 of 2
    • Using your plastic opening tool, begin carefully prying the plastic shell from the phone.
    • Make your way around the edge slowly and lift the shell off when you have made a full circuit.
  5. Blu Studio 5.5 Camera Replacement: step 5, image 1 of 1
    • Locate and unplug seven connectors on the motherboard.
    • Those marked in red are pulled straight up, away from the phone.
    • The connector marked in orange is pulled out horizontally.
  6. Blu Studio 5.5 Camera Replacement: step 6, image 1 of 1
    • Unscrew the three 3.5mm screws securing the motherboard in place.
  7. Blu Studio 5.5 Camera Replacement: step 7, image 1 of 1
    • Using the plastic opening tool, you can now lift the motherboard straight up and out.
  8. Blu Studio 5.5 Camera Replacement: step 8, image 1 of 1
    • Carefully wedge the plastic remover tool underneath the corner of the camera module and slowly pry until it comes free.
  9. Blu Studio 5.5 Camera Replacement: step 9, image 1 of 3 Blu Studio 5.5 Camera Replacement: step 9, image 2 of 3 Blu Studio 5.5 Camera Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to lift the camera module out, taking care not to get any fingerprints on it.
    • During reassembly, make sure the ribbon attached to the camera goes up and through the square hole on the motherboard so it is able to reconnect properly.
3 other people completed this guide.
Brian Sullivan
647 Reputation
3 Guides authored
UMass Dartmouth, Team 1-2, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-2, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G2
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,217
