Blu L120 Loudspeaker Replacement
    1. Blu L120 Loudspeaker Replacement, Open the back panel: step 1, image 1 of 3 Blu L120 Loudspeaker Replacement, Open the back panel: step 1, image 2 of 3 Blu L120 Loudspeaker Replacement, Open the back panel: step 1, image 3 of 3
      • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
      Ask FixBot
    2. Blu L120 Loudspeaker Replacement, Screw removal: step 2, image 1 of 3 Blu L120 Loudspeaker Replacement, Screw removal: step 2, image 2 of 3 Blu L120 Loudspeaker Replacement, Screw removal: step 2, image 3 of 3
      • Remove these nine screws with a small philips screwdriver. They are all of the same size
      • There is a small screw hidden under the warranty sticker. You may either remove or poke through it.
      • *WARNING* by doing this you will void your manufacturer warranty.
      Ask FixBot
    3. Blu L120 Loudspeaker Replacement, Rear panel removal: step 3, image 1 of 3 Blu L120 Loudspeaker Replacement, Rear panel removal: step 3, image 2 of 3 Blu L120 Loudspeaker Replacement, Rear panel removal: step 3, image 3 of 3
      • Use the Spudger to gently separate the panel from the frame, starting from the bottom left corner.
      • Then work your way along the edges of the phone.
      Ask FixBot
    4. Blu L120 Loudspeaker Replacement, Separate back panel and frame: step 4, image 1 of 3 Blu L120 Loudspeaker Replacement, Separate back panel and frame: step 4, image 2 of 3 Blu L120 Loudspeaker Replacement, Separate back panel and frame: step 4, image 3 of 3
      • Continue using the spudger around the back panel of the phone to separate both pieces.
      • Once you have gone around the entire frame, use both hands to pull it apart.
      Ask FixBot
    5. Blu L120 Loudspeaker Replacement, Speaker Removal: step 5, image 1 of 2 Blu L120 Loudspeaker Replacement, Speaker Removal: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to grab the speaker assembly from the back of the panel and gently remove the it from the frame. (double sided tape is used to hold it together)
      • Install the new speaker, and follow the guide in reverse to reassemble the phone.
      Ask FixBot
Julio
695 Reputation
6 Guides authored
Gateway, Team 1-5, Johnson Fall 2014 Member of Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Members
72 Guides authored
1 Guide Comment
where can i get the Loud speaker
Shamar Houston - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 107
All Time: 778
