Up to 20% off select tools
Blu Grand M2 Display Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
68
All Time:
2,442
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If your Blu Grand M2 smartphone has a display problem—a shattered screen, a screen with vertical lines, or a flickering screen, use this guide to replace the display screen of your phone in six easy steps.
The display screen is used to provide inputs and outputs to the user. A faulty display screen will prevent a user from using the smartphone functionalities such as the touch screen feature.
Before using this guide, be aware that this solution works only with the Blu Grand M2 smartphones. Be sure to check your phone model before using this guide.
Step 5 requires you to use an iOpener from the iFixit toolkit before you can remove the display screen. Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
    1. Blu Grand M2 Display Replacement, Display: step 1, image 1 of 2 Blu Grand M2 Display Replacement, Display: step 1, image 2 of 2
      • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
      • Locate the two Torx screws at the bottom of the phone and remove them.
      Ask FixBot
    2. Blu Grand M2 Display Replacement: step 2, image 1 of 1
      • Use the pry tool to wedge between the phone's frame and the back plate.
      • Carefully remove the back plate using the suction tool.
      • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
      Ask FixBot
    3. Blu Grand M2 Display Replacement: step 3, image 1 of 3 Blu Grand M2 Display Replacement: step 3, image 2 of 3 Blu Grand M2 Display Replacement: step 3, image 3 of 3
      • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
      • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
      • Disconnect the two remaining connectors shown in figure 3.
      Ask FixBot
    4. Blu Grand M2 Display Replacement: step 4, image 1 of 2 Blu Grand M2 Display Replacement: step 4, image 2 of 2
      • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
      • After removing the six Phillips screws, remove the motherboard piece.
      Ask FixBot
    5. Blu Grand M2 Display Replacement: step 5, image 1 of 1
      • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
      • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
      • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
      Ask FixBot
    6. Blu Grand M2 Display Replacement: step 6, image 1 of 3 Blu Grand M2 Display Replacement: step 6, image 2 of 3 Blu Grand M2 Display Replacement: step 6, image 3 of 3
      • Using the suction tool, slowly pull out the display screen shown in figure 1.
      • Use the pry tool to completely detach the display screen from the phone.
      • When the display is removed, attach your new screen.
      • After applying the new screen, use the steps in reverse order to reassemble the phone.
      Ask FixBot
Author
with
Christopher
192 Reputation
1 Guide authored
Gateway, Team S1-G3, Luster Fall 2018 Member of Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Members
48 Guides authored
1 Guide Comment
What type of torx screwdriver did you use?
npyles86 - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 68
All Time: 2,442
