Blu Grand M2 Charging Port Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
74
All Time:
960
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide was made to help you if you are experiencing a BLU GRAND M2 charging failure. This guide will help you replace the charging port for the BLU GRAND M2.
In order to follow this guide, you will need to solder. Check out the How to Solder and Desolder Connections guide before you start if you are unfamiliar or need a refresher. Also be sure to power off the phone before beginning your repair.
Parts
Tools
    1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: step 1, image 1 of 1
      • Remove the screws with the T2 Torx screwdriver.
      • Place screws off to the side.
      Ask FixBot
    2. Blu Grand M2 Charging Port Assembly Replacement: step 2, image 1 of 2 Blu Grand M2 Charging Port Assembly Replacement: step 2, image 2 of 2
      • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
      • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
      • Make sure to disconnect all other connections from the camera.
      Ask FixBot
    3. Blu Grand M2 Charging Port Assembly Replacement: step 3, image 1 of 1
      • Carefully pry the motherboard assembly from the phone.
      • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
      • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
      • After installing the new port, repeat the steps in reverse order to reassemble the phone.
      • How to Solder and Desolder Connections
      Ask FixBot
Richard Hills
150 Reputation
1 Guide authored
Gateway, Team S1-G3, Luster Fall 2018 Member of Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 74
All Time: 960
