Blu Grand M Microphone Replacement
    1. Blu Grand M Microphone Replacement, Battery: step 1, image 1 of 2 Blu Grand M Microphone Replacement, Battery: step 1, image 2 of 2
      • Remove the two plastic plates with a plastic opening tool.
      Ask FixBot
    2. Blu Grand M Microphone Replacement: step 2, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
      Ask FixBot
    3. Blu Grand M Microphone Replacement: step 3, image 1 of 3 Blu Grand M Microphone Replacement: step 3, image 2 of 3 Blu Grand M Microphone Replacement: step 3, image 3 of 3
      • Remove SIM card tray with paperclip or SIM card tray removal tool.
      • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
      Ask FixBot
    4. Blu Grand M Microphone Replacement: step 4, image 1 of 2 Blu Grand M Microphone Replacement: step 4, image 2 of 2
      • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
      • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
      Ask FixBot
    1. Blu Grand M Microphone Replacement, Speaker: step 5, image 1 of 2 Blu Grand M Microphone Replacement, Speaker: step 5, image 2 of 2
      • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
      • Remove the 4.0mm screw with a Phillips #000 screwdriver.
      • Using the blue plastic opening tool, remove the exterior cover.
      Ask FixBot
    2. Blu Grand M Microphone Replacement: step 6, image 1 of 3 Blu Grand M Microphone Replacement: step 6, image 2 of 3 Blu Grand M Microphone Replacement: step 6, image 3 of 3
      • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
      • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
      • Use the plastic opening tool to remove the speaker.
      Ask FixBot
    1. Blu Grand M Microphone Replacement, Microphone: step 7, image 1 of 2 Blu Grand M Microphone Replacement, Microphone: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the black wire with a pair of tweezers.
      • The black wire can swivel out of the way to easily access the next microphone.
      Ask FixBot
    2. Blu Grand M Microphone Replacement: step 8, image 1 of 2 Blu Grand M Microphone Replacement: step 8, image 2 of 2
      • Use a pair of tweezers to remove the orange data cable as shown.
      Ask FixBot
    3. Blu Grand M Microphone Replacement: step 9, image 1 of 3 Blu Grand M Microphone Replacement: step 9, image 2 of 3 Blu Grand M Microphone Replacement: step 9, image 3 of 3
      • There will be glue holding the wires down, and they can be glued back in place after.
      • Use the plastic opening tool to lift the microphone out of place.
      • Use a pair of tweezers to lift the microphone out of the phone.
      Ask FixBot
Cameron Retzlaff
608 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 63
All Time: 599
