Up to 20% off select tools
Blu Grand M Display Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
12
Past 30 Days:
63
All Time:
667
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 6 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the phone screen, also called the digitizer, on your BLU Grand M is cracked, follow this guide to replace it. The smart phone screen, also known as the digitizer, is adhered to the smartphone frame with an adhesive. The digitizer is easy to remove and does not require many but you will need a heat gun or hair dryer— use caution when applying heat to the device.
    1. Blu Grand M Display Replacement, Display: step 1, image 1 of 1
      • Trace the outer black edge of the phone screen in a continuous circle with a hairdryer or heat gun to melt the adhesive.
      • Melting the adhesive can take between 2-3 minutes.
      Ask FixBot
    2. Blu Grand M Display Replacement: step 2, image 1 of 3 Blu Grand M Display Replacement: step 2, image 2 of 3 Blu Grand M Display Replacement: step 2, image 3 of 3
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Insert an opening pick between the screen and the raised black plastic frame.
      • The black plastic frame is located inside and above the phone's silvery outer metal frame.
      • Insert the flat blade of a nylon halberd spudger between the screen and the black plastic frame.
      • Pull the spudger blade through the adhesive around the circumference of the screen.
      Ask FixBot
    3. Blu Grand M Display Replacement: step 3, image 1 of 3 Blu Grand M Display Replacement: step 3, image 2 of 3 Blu Grand M Display Replacement: step 3, image 3 of 3
      • Apply the suction cup to the phone screen, pressing lightly on the suction cup to remove air and form a tight seal.
      • The adhesive may have cooled from the time since step 1 and rebonded to the phone screen. Reheat the adhesive if necessary to return to a liquid state.
      • Pull on the handle to lift the screen free from the device.
      Ask FixBot
Finish Line
Author
with
Liam Rollins
253 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 63
All Time: 667
