Blu Dash 5.0 Dual SIM Speaker Replacement
    1. Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: step 1, image 1 of 2 Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: step 1, image 2 of 2
      • Make sure device is disconnected and turned off.
      • Locate the groove at the bottom left corner of the phone.
      • Insert the plastic opening tool in the groove and pry it open.
      • Lift the back cover of the phone using your hands.
      Ask FixBot
    2. Blu Dash 5.0 Dual SIM Speaker Replacement: step 2, image 1 of 1
      • Pry the battery out from the back of the phone using the plastic opening tool.
      Ask FixBot
    3. Blu Dash 5.0 Dual SIM Speaker Replacement: step 3, image 1 of 1
      • Remove the 12 screws located at the back panel of the phone using a J000 screwdriver.
      • The red circles are screw holes that hold the 3.5mm length Phillips screw.
      • The orange circles are screw holes that hold the 2.5mm length Phillips screw.
      Ask FixBot
    4. Blu Dash 5.0 Dual SIM Speaker Replacement: step 4, image 1 of 3 Blu Dash 5.0 Dual SIM Speaker Replacement: step 4, image 2 of 3 Blu Dash 5.0 Dual SIM Speaker Replacement: step 4, image 3 of 3
      • Remove the back panel of the phone with your hand.
      • Carefully remove the plastic back panel to avoid breaking it.
      Ask FixBot
    5. Blu Dash 5.0 Dual SIM Speaker Replacement: step 5, image 1 of 1
      • Remove the antenna cable connectors using a spudger.
      Ask FixBot
    6. Blu Dash 5.0 Dual SIM Speaker Replacement: step 6, image 1 of 1
      • Unscrew the 2.5mm screws from the circuit board holding the speaker at the bottom of the phone.
      Ask FixBot
    7. Blu Dash 5.0 Dual SIM Speaker Replacement: step 7, image 1 of 2 Blu Dash 5.0 Dual SIM Speaker Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Flip the ZIF flap up with tweezers.
      • Remove the ribbon cable with tweezers.
      • The ribbon cable is sensitive and needs to be removed carefully to insure its integrity.
      Ask FixBot
    8. Blu Dash 5.0 Dual SIM Speaker Replacement: step 8, image 1 of 2 Blu Dash 5.0 Dual SIM Speaker Replacement: step 8, image 2 of 2
      • Remove the speaker panel with the plastic opening tool.
      • The panel is glued onto the device and will require extra force to remove.
      Ask FixBot
Mukish Kumar Munyady
201 Reputation
2 Guides authored
IUPUI, Team 1-1, Baechle Spring 2017 Member of IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 553
