Blu Dash 5.0 Dual SIM Back Camera Replacement
    1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: step 1, image 1 of 2 Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: step 1, image 2 of 2
      • Make sure device is disconnected and turned off.
      • Locate the groove on the bottom left corner of the back of the phone.
      • Insert the plastic opening tool into the groove and pry it open.
      • Lift the back cover of the phone using your hands.
      Ask FixBot
    2. Blu Dash 5.0 Dual SIM Back Camera Replacement: step 2, image 1 of 1
      • Pry the battery out using the plastic opening tool.
      Ask FixBot
    3. Blu Dash 5.0 Dual SIM Back Camera Replacement: step 3, image 1 of 1
      • Remove the 12 screws on the back panel using a J000 screwdriver.
      • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
      • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
      Ask FixBot
    4. Blu Dash 5.0 Dual SIM Back Camera Replacement: step 4, image 1 of 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: step 4, image 2 of 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: step 4, image 3 of 3
      • Peel off the back panel with your hand.
      • Remove the back panel slowly to avoid breaking it.
      Ask FixBot
    5. Blu Dash 5.0 Dual SIM Back Camera Replacement: step 5, image 1 of 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: step 5, image 2 of 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Flip up the ZIF flap using the spudger.
      • Gently remove the ribbon cable with tweezers.
      • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
      • Remove the back camera using tweezers.
      Ask FixBot
Mukish Kumar Munyady
201 Reputation
2 Guides authored
IUPUI, Team 1-1, Baechle Spring 2017 Member of IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 101
All Time: 792
