Blink Video Doorbell LED Light Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
62
All Time:
488
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Blink Video Doorbell is a doorbell to provide extra security to your residence by giving you an accessible view whenever necessary. The lens is an added-on part of the device. It allows you to have a consistent, controllable, and color-accurate light source. Refer to the troubleshooting page if there are issues with the LED lights which could be connected to causes such as battery failure, software failure, and a frozen screen. If you need to take out the LEDs, use this guide to remove and replace the LEDs.
Tools
    1. Blink Video Doorbell LED Light Replacement, Battery: step 1, image 1 of 3 Blink Video Doorbell LED Light Replacement, Battery: step 1, image 2 of 3 Blink Video Doorbell LED Light Replacement, Battery: step 1, image 3 of 3
      • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
      • The device will click off the mount.
      • Push the device up from the mount and slide it off.
      Ask FixBot
    2. Blink Video Doorbell LED Light Replacement: step 2, image 1 of 3 Blink Video Doorbell LED Light Replacement: step 2, image 2 of 3 Blink Video Doorbell LED Light Replacement: step 2, image 3 of 3
      • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
      • Remove the battery cover.
      Ask FixBot
    3. Blink Video Doorbell LED Light Replacement: step 3, image 1 of 3 Blink Video Doorbell LED Light Replacement: step 3, image 2 of 3 Blink Video Doorbell LED Light Replacement: step 3, image 3 of 3
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
      Ask FixBot
    1. Blink Video Doorbell LED Light Replacement, Back Panel: step 4, image 1 of 3 Blink Video Doorbell LED Light Replacement, Back Panel: step 4, image 2 of 3 Blink Video Doorbell LED Light Replacement, Back Panel: step 4, image 3 of 3
      • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
      • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
      • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
      Ask FixBot
    1. Blink Video Doorbell LED Light Replacement, LED Light: step 5, image 1 of 3 Blink Video Doorbell LED Light Replacement, LED Light: step 5, image 2 of 3 Blink Video Doorbell LED Light Replacement, LED Light: step 5, image 3 of 3
      • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
      • Use an opening tool to release the motherboard from the device.
      Ask FixBot
    2. Blink Video Doorbell LED Light Replacement: step 6, image 1 of 3 Blink Video Doorbell LED Light Replacement: step 6, image 2 of 3 Blink Video Doorbell LED Light Replacement: step 6, image 3 of 3
      • Use a soldering iron to desolder the LED connections from the motherboard.
      Ask FixBot
Kayla Crai
510 Reputation
4 Guides authored
UMass Dartmouth, Team 1-1, Konn Fall 2024 Member of UMass Dartmouth, Team 1-1, Konn Fall 2024
UMASSD-KONN-F24S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 62
All Time: 488
