Blink Video Doorbell Daughterboard Replacement
  1. Blink Video Doorbell Daughterboard Replacement, Battery: step 1, image 1 of 3 Blink Video Doorbell Daughterboard Replacement, Battery: step 1, image 2 of 3 Blink Video Doorbell Daughterboard Replacement, Battery: step 1, image 3 of 3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Daughterboard Replacement: step 2, image 1 of 3 Blink Video Doorbell Daughterboard Replacement: step 2, image 2 of 3 Blink Video Doorbell Daughterboard Replacement: step 2, image 3 of 3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Daughterboard Replacement: step 3, image 1 of 3 Blink Video Doorbell Daughterboard Replacement: step 3, image 2 of 3 Blink Video Doorbell Daughterboard Replacement: step 3, image 3 of 3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Daughterboard Replacement, Back Panel: step 4, image 1 of 3 Blink Video Doorbell Daughterboard Replacement, Back Panel: step 4, image 2 of 3 Blink Video Doorbell Daughterboard Replacement, Back Panel: step 4, image 3 of 3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Daughterboard Replacement, Lens: step 5, image 1 of 3 Blink Video Doorbell Daughterboard Replacement, Lens: step 5, image 2 of 3 Blink Video Doorbell Daughterboard Replacement, Lens: step 5, image 3 of 3
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Daughterboard Replacement: step 6, image 1 of 2 Blink Video Doorbell Daughterboard Replacement: step 6, image 2 of 2
    • Carefully lift up the small daughterboard which contains the camera.
    • Remove two 5 mm screws from the back of the camera using a Phillips #0 screwdriver.
  7. Blink Video Doorbell Daughterboard Replacement: step 7, image 1 of 2 Blink Video Doorbell Daughterboard Replacement: step 7, image 2 of 2
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the lens.
  8. Blink Video Doorbell Daughterboard Replacement, Daughterboard: step 8, image 1 of 1
    • After removing the lens, you are left with the daughterboard.
Kayla Crai
510 Reputation
4 Guides authored
UMass Dartmouth, Team 1-1, Konn Fall 2024 Member of UMass Dartmouth, Team 1-1, Konn Fall 2024
UMASSD-KONN-F24S1G1
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 39
All Time: 480
