Blink Outdoor 4 Battery Replacement
    1. Blink Outdoor 4 Battery Replacement, Blink Outdoor 4 Battery: step 1, image 1 of 1
      • If the mounting bracket is attached, remove it from the back of the device.
      • Flip the camera so the bottom is facing up.
      • The word 'Blink' should be at the top.
      Ask FixBot
    2. Blink Outdoor 4 Battery Replacement: step 2, image 1 of 3 Blink Outdoor 4 Battery Replacement: step 2, image 2 of 3 Blink Outdoor 4 Battery Replacement: step 2, image 3 of 3
      • Insert the swivel multi-tool (included in the Blink Outdoor 4 box) into the small notch located in the silver circle in the center of the device.
      • Twist to the left until you hear a click.
      Ask FixBot
    3. Blink Outdoor 4 Battery Replacement: step 3, image 1 of 2 Blink Outdoor 4 Battery Replacement: step 3, image 2 of 2
      • Use a spudger to gently pry the back casing off the device.
      • Remove the two old batteries.
      • Insert two new AA 1.5V Lithium batteries in the assigned compartments.
      • Ensure that the new batteries are aligned with the correct polarity.
      • When reattaching the back casing, turn the swivel tool to the right.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Delaney Hye
749 Reputation
5 Guides authored
Texas Tech, Team 11-5, Weston Spring 2026 Member of Texas Tech, Team 11-5, Weston Spring 2026
TTU-WESTON-S26S11G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 78
All Time: 358
