Blank Screen Repair Techniques
      • If your Wii isn't outputting any video, the last thing you'd want to do is take it apart when the problem turns out to be that you forgot to turn on your TV! Therefore, to rule that out, I suggest that you ensure that your console and your TV are both powered on, and your TV is set to the correct source.
      • If that doesn't work...
      Ask FixBot
      • If you have a Wii Mini (Red and black, toploading), check to be sure that you're using an A/V cable (Red, white, and yellow plugs) and not a Component cable (Two red plugs, one white plug, one green plug, and one blue plug). The Wii Mini is incompatible with component cables. Skip this step if you aren't fixing a Wii Mini.
      Ask FixBot
      • Yeah, yeah, we've all seen it before. You turn off your Wii and your Samsung TV (If you don't have a Samsung TV, just go with it) displays, "Check cable connections". But this time, you actually might need to do that! It's at least worth trying before you resort to dismantling your Wii, anyway. Be sure all the cables are in and reconnect if needed.
      Ask FixBot
      • This may sound crazy, but it actually helps sometimes, especially if your TV's ports are... finicky. Twist 'em a little... pull 'em out... put 'em back in... whatever you think falls under "Fiddling"! Okay, maybe not ANYTHING. Just do whatever sort of thing you think would help make a better connection. Don't hold back (too much)!
      Ask FixBot
      • If you happen to have an extra A/V cable handy, test it to rule out the current cable as a problem. If that doesn't work, see if you can get your hands on another one, just to be certain it's not the cable.
      • IMPORTANT: As mentioned in previous steps, be sure to connect the cables correctly, and be sure that they are "in" well enough.
      Ask FixBot
      • For people who happen to have more than one compatible TV, you may find it useful to know whether or not it's the TV by testing your Wii on a different one. This is optional, but it's recommended if you have more than one TV and are unsure if your TV is causing the problem.
      Ask FixBot
      • Okay... some of you are, perhaps, wondering how one might do this while unable to see anything on the screen. It's simple, really: By holding DOWN on the Wii remote's D-pad (while holding the Wii remote in vertical position) and RESET on the console while it's booting up, the resolution setting is reset to 480i. See? Simple!
      Ask FixBot
      • And how do you do that? Well, you unplug the console from the AC adapter, then wait a few seconds (as a rule of thumb, I would say that anywhere from 15 seconds to a minute should do the trick), then plug it back in.
      Ask FixBot
      • If your TV has a settings menu, check it! Be sure there aren't any odd zoom or pan settings active, and if they are, turn them off. Some TVs also allow you to reset settings to factory defaults, so try this if all else fails.
      Ask FixBot
Still no video? There may be a problem with the console itself. You may wish to re-test some of the above methods before coming to this conclusion. Otherwise, it is likely a hardware issue and your solution will be found elsewhere.
Fixer of Stuff
1,360 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 32
Past 30 Days: 162
All Time: 1,177
