Blackview BV9800 Pro Screen Replacement
    1. Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: step 1, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: step 1, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 1/2: step 1, image 3 of 3
      • Flip the phone over.
      • Remove the four T5 screws.
      • Remove the single T5 screw from the bottom, next to the charging port.
      Ask FixBot
    2. Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: step 2, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: step 2, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Removing back cover 2/2: step 2, image 3 of 3
      • Remove the screws from the sides.
      • Remove the screws holding the camera frame.
      Ask FixBot
    3. Blackview BV9800 Pro Screen Replacement, Removing side bezels: step 3, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Removing side bezels: step 3, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Removing side bezels: step 3, image 3 of 3
      • Pry out the sim car holder
      • It has a dual sim card holder, but to remove the second tray you need a pin or an iphone sim card opener to push it out.
      • Use a spudger or a utility knife to pry off the side bezels.
      Ask FixBot
    4. Blackview BV9800 Pro Screen Replacement, Separate the back cover: step 4, image 1 of 2 Blackview BV9800 Pro Screen Replacement, Separate the back cover: step 4, image 2 of 2
      • Pry in one corner and separate the back.
      Ask FixBot
    5. Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: step 5, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: step 5, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Disconnect connetctors: step 5, image 3 of 3
      • Use a plastic spudger to disconnect the flex connectors.
      Ask FixBot
    6. Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: step 6, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: step 6, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Disconnect flex and antenna: step 6, image 3 of 3
      • Use a plastic spudger to disconnect the flex connector and the antenna
      Ask FixBot
    7. Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: step 7, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: step 7, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Remove top PCB and plastic enclosure: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Heat up this PCB with either iOpener or a heat gun on low temp (100-120 Celsius) to loosen the adhesive and pry it off from the side.
      • Remove the screws.
      • The last screw is under a tamper-proof sticker
      • Use plastic spudger or tweezers to disconnect the camera flex cable from the top
      • Gently lift up the plasctic cover from the right side. It is still connected to the board below!
      • Disconnect the flex cable
      • Disconnect the antenna
      Ask FixBot
    8. Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: step 8, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: step 8, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Unscrew battery shield and peel flex cable: step 8, image 3 of 3
      • Remove the screws from the battery cover
      • Carefully release the ribbon cable from the battery shield. It is stuck down at two points.
      Ask FixBot
    9. Blackview BV9800 Pro Screen Replacement, Disconnect connectors: step 9, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: step 9, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Disconnect connectors: step 9, image 3 of 3
      • Disconnect the flex connectors and remove the battery
      Ask FixBot
    10. Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: step 10, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: step 10, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Motherboard disassembly: step 10, image 3 of 3
      • Remove two J000 screws
      • Carefully pry up the camera. Heat from the glass side if necessary.
      • Unscrew and remove the camera assembly
      Ask FixBot
    11. Blackview BV9800 Pro Screen Replacement, Remove light sensor: step 11, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Remove light sensor: step 11, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Remove light sensor: step 11, image 3 of 3
      • Heat the light sensor from both sides to loosen the adhesive and gently pry them out of their sockets
      • Using tweezers slowly and carefully lift out the light sensor
      Ask FixBot
    12. Blackview BV9800 Pro Screen Replacement, Remove audio jack: step 12, image 1 of 3 Blackview BV9800 Pro Screen Replacement, Remove audio jack: step 12, image 2 of 3 Blackview BV9800 Pro Screen Replacement, Remove audio jack: step 12, image 3 of 3
      • Use some isopropyl alcohol if necessary to loosen the glue further on the audio jack
      • Grab it with strong tweezers and wiggle from side to side and upwards until it comes out. Heat further if necessary.
      • Lift it out and transfer to the new screen.
      Ask FixBot
    13. Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: step 13, image 1 of 2 Blackview BV9800 Pro Screen Replacement, Remove ribbon cable and charging port: step 13, image 2 of 2
      • Gently peel the flex cable u p and transfer to the new assembly.
      • Heat it up if the adhesive is too strong.
      • Heat up and pry up the bottom PCB (charging port) and transfer to the new screen.
      Ask FixBot
10 other people completed this guide.
honakrisi
4,573 Reputation
9 Guides authored
3 Guide Comments
You saved my mobile phone. Even I did not replace the screen, I just replace the battery. I forgot some connectors but your post remind me and the mobile back to work!
Colin Wen - Reply Share
I’m glad that you managed to save your device!
honakrisi - Reply Share
Where can I get black view repair shop in Ghana and their number
Emmanuel offei - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 145
All Time: 6,626
