Blackberry Torch 9800 Rear Camera
    1. Blackberry Torch 9800 Rear Camera, Rear Camera: step 1, image 1 of 2 Blackberry Torch 9800 Rear Camera, Rear Camera: step 1, image 2 of 2
      • Remove the back cover.
      • Remove the battery.
      • Use a T7 Torx screwdriver to remove the four screws.
      Ask FixBot
    2. Blackberry Torch 9800 Rear Camera: step 2, image 1 of 2 Blackberry Torch 9800 Rear Camera: step 2, image 2 of 2
      • Use the iFixit opening tool to pry off the side trim.
      • When the trim is loose:
      • Push the top section backward.
      • Push the bottom section forward.
      • Remove the trim.
      Ask FixBot
    3. Blackberry Torch 9800 Rear Camera: step 3, image 1 of 3 Blackberry Torch 9800 Rear Camera: step 3, image 2 of 3 Blackberry Torch 9800 Rear Camera: step 3, image 3 of 3
      • Use a T7 Torx screwdriver to remove the two screws.
      • Use the iFixit opening tool to remove the back panel.
      Ask FixBot
    4. Blackberry Torch 9800 Rear Camera: step 4, image 1 of 2 Blackberry Torch 9800 Rear Camera: step 4, image 2 of 2
      • Use a spudger to lift the camera module from its slot.
      • Wiggle the camera gently from the left and right sides.
      • Caution: Do not pry from the top or bottom. This may damage the connectors.
      Ask FixBot
To reassemble your device, follow these steps in reverse order. Ensure the camera module is properly aligned and all screws are securely tightened before replacing the back cover and battery.
0delete
189 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 23
All Time: 653
