Blackberry Storm 9530 Battery Replacement
    1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: step 1, image 1 of 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: step 1, image 2 of 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: step 1, image 3 of 3
      • Locate the two switches toward the bottom corners of the device's back cover.
      • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
      • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
      Ask FixBot
    2. Blackberry Storm 9530 Battery Replacement: step 2, image 1 of 1
      • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
      • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
      • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
      Ask FixBot
melanie lim
607 Reputation
6 Guides authored
Cal Poly, Team 9-16, Regan Spring 2014 Member of Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 Members
90 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 32
All Time: 2,203
