Blackberry Pearl 8100 Trackball Replacement
  1. Blackberry Pearl 8100 Trackball Replacement, Battery: step 1, image 1 of 1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    Ask FixBot
    • Remove the battery located directly below back panel.
    Ask FixBot
  2. Blackberry Pearl 8100 Trackball Replacement, Keyboard: step 3, image 1 of 1
    • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
    Ask FixBot
  3. Blackberry Pearl 8100 Trackball Replacement: step 4, image 1 of 2 Blackberry Pearl 8100 Trackball Replacement: step 4, image 2 of 2
    • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
    Ask FixBot
  4. Blackberry Pearl 8100 Trackball Replacement: step 5, image 1 of 1
    • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
    Ask FixBot
  5. Blackberry Pearl 8100 Trackball Replacement: step 6, image 1 of 1
    • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
    Ask FixBot
  6. Blackberry Pearl 8100 Trackball Replacement: step 7, image 1 of 2 Blackberry Pearl 8100 Trackball Replacement: step 7, image 2 of 2
    • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
    Ask FixBot
  7. Blackberry Pearl 8100 Trackball Replacement: step 8, image 1 of 1
    • Separate the logic board from the front panel.
    Ask FixBot
  8. Blackberry Pearl 8100 Trackball Replacement: step 9, image 1 of 2 Blackberry Pearl 8100 Trackball Replacement: step 9, image 2 of 2
    • Gently remove the keyboard from front casing. It should snap out of place.
    Ask FixBot
  9. Blackberry Pearl 8100 Trackball Replacement, Trackball: step 10, image 1 of 1
    • Some of these parts are fairly small and fragile; be sure to keep them in a safe place where they won't be damaged if you intend to reuse them.
    • Before repairing device, make sure to power off the device.
    • Once powered off, begin repair by removing the larger chrome ring holding the track ball in place by using the spudger to gently wedge the top ring away, approaching from the front face.
    Ask FixBot
  10. Blackberry Pearl 8100 Trackball Replacement: step 11, image 1 of 1
    • Be sure to keep all pieces in a safe place where they won't be lost or damaged if you intend to reuse them.
    • Remove the smaller chrome inner ring surrounding the trackball; you should be able to be simply lift it by hand.
    • If ring seems to be stuck, gently pry it off using your spudger tool.
    Ask FixBot
  11. Blackberry Pearl 8100 Trackball Replacement: step 12, image 1 of 1
    • Once the ring has been remove, proceed to removing the trackball housing; it should be able to be removed by hand.
    • After removing old trackball, replace it with a new one and proceed to following these instructions in reversed order to reassemble your device.
    Ask FixBot
5 other people completed this guide.
Robert Cronin
544 Reputation
6 Guides authored
Cal Poly, Team 34-57, Forte Spring 2010 Member of Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Members
18 Guides authored
1 Guide Comment
why dissasemble the entire device, just remove the chrome ring....
Latios Eon - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 51
All Time: 8,392
