Blackberry Pearl 8100 SIM Card Replacement
Views: 10K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
109
All Time:
10,329
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Very easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
Follow this guide to install a SIM card in the Blackberry Pearl 8100.
    1. Blackberry Pearl 8100 SIM Card Replacement, Battery: step 1, image 1 of 1
      • Before working on the phone, be sure that the device is turned off.
      • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
      Ask FixBot
      • Remove the battery located directly below back panel.
      Ask FixBot
    1. Blackberry Pearl 8100 SIM Card Replacement, SIM Card: step 3, image 1 of 1
      • Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
      Ask FixBot
    2. Blackberry Pearl 8100 SIM Card Replacement: step 4, image 1 of 1
      • Lift the metal casing.
      Ask FixBot
      • Insert an SD Card.
      Ask FixBot
2 other people completed this guide.
Robert Cronin
544 Reputation
6 Guides authored
Cal Poly, Team 34-57, Forte Spring 2010 Member of Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Members
72 Guides authored
1 Guide Comment
Doesn't work with "upgraded" O2 sim for 4G and 5G networks! Mobile doesn't work at all. 03/05/2025. Just a con by O2?
Allan West - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 109
All Time: 10,329
