Blackberry PRIV Rear-Facing Camera Replacement
  1. Blackberry PRIV Rear-Facing Camera Replacement, Rear Casing: step 1, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement, Rear Casing: step 1, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement, Rear Casing: step 1, image 3 of 3
    • Look for the two small holes at the top of your device.
    • Use a SIM eject tool to push down into the holes which lifts the SIM and SD trays.
    • Pull the trays up and out of the device.
    Ask FixBot
  2. Blackberry PRIV Rear-Facing Camera Replacement: step 2, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 2, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 2, image 3 of 3
    • Insert an opening pick in the seam between the rear casing and chassis. Apply downward pressure to pry the casing upward.
    • Follow this procedure for only the right, left, and top side of the casing.
    Ask FixBot
  3. Blackberry PRIV Rear-Facing Camera Replacement: step 3, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 3, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 3, image 3 of 3
    • Remove the rear casing by sliding the case down and out.
    Ask FixBot
  4. Blackberry PRIV Rear-Facing Camera Replacement, Battery: step 4, image 1 of 2 Blackberry PRIV Rear-Facing Camera Replacement, Battery: step 4, image 2 of 2
    • Remove the two 3.3 mm T4 Torx screws that secure the battery connector.
    • There may be a plastic protector covering the circuit board and battery. Remove the plastic protector to begin.
    Ask FixBot
  5. Blackberry PRIV Rear-Facing Camera Replacement: step 5, image 1 of 2 Blackberry PRIV Rear-Facing Camera Replacement: step 5, image 2 of 2
    • Use an opening tool to lift and disconnect the battery connector.
    Ask FixBot
  6. Blackberry PRIV Rear-Facing Camera Replacement: step 6, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 6, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 6, image 3 of 3
    • Pull on the plastic tab to remove the battery from the device.
    • For easier removal, use a blow dryer to warm the battery glue.
    • Be careful to not overheat the battery or puncture the battery as lithium batteries are dangerous.
    Ask FixBot
  7. Blackberry PRIV Rear-Facing Camera Replacement, Rear-Facing Camera: step 7, image 1 of 1
    • Remove the seven 3.3 mm T4 Torx screws that secure the motherboard.
    Ask FixBot
  8. Blackberry PRIV Rear-Facing Camera Replacement: step 8, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 8, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 8, image 3 of 3
    • Remove the two 3.3 mm T4 Torx screws that secure the speaker casing.
    • Lift and remove the speaker casing.
    Ask FixBot
  9. Blackberry PRIV Rear-Facing Camera Replacement: step 9, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 9, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 9, image 3 of 3
    • Remove the one 3.3 mm T4 Torx screw that secures the headphone jack.
    • Lift and remove the headphone jack.
    Ask FixBot
  10. Blackberry PRIV Rear-Facing Camera Replacement: step 10, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 10, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 10, image 3 of 3
    • Use an opening tool to lift and disconnect the three press connectors.
    Ask FixBot
  11. Blackberry PRIV Rear-Facing Camera Replacement: step 11, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 11, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 11, image 3 of 3
    • Lift the motherboard from the device.
    • Do not pull the circuit board with too much force as there is a strip connected under.
    • Using two fingers, pinch the on the strip as close to the connector as possible.
    • Lift and disconnect the connector from the motherboard.
    Ask FixBot
  12. Blackberry PRIV Rear-Facing Camera Replacement: step 12, image 1 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 12, image 2 of 3 Blackberry PRIV Rear-Facing Camera Replacement: step 12, image 3 of 3
    • Turn the motherboard around.
    • Use an opening tool to lift and disconnect the camera connector.
    Ask FixBot
  13. Blackberry PRIV Rear-Facing Camera Replacement: step 13, image 1 of 2 Blackberry PRIV Rear-Facing Camera Replacement: step 13, image 2 of 2
    • Lift and remove the camera from the circuit board.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Benjamin Olvera
563 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 23
All Time: 227
