Blackberry Curve 9300 Screen Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
93
All Time:
5,439
Comments: 1
1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide was written to aid with Blackberry Curve screen replacement. Following the steps below should provide relatively simple means of achieving this goal.
Tools
    1. Blackberry Curve 9300 Screen Replacement, Battery: step 1, image 1 of 1
      • Place your Blackberry face down in front of you.
      Ask FixBot
    2. Blackberry Curve 9300 Screen Replacement: step 2, image 1 of 1
      • Locate the indent on the bottom of the back cover.
      • Use your fingernail to lift and remove the back cover.
      Ask FixBot
    3. Blackberry Curve 9300 Screen Replacement: step 3, image 1 of 1
      • From the top, use your fingernail to lift and remove the battery.
      Ask FixBot
    1. Blackberry Curve 9300 Screen Replacement, Keyboard: step 4, image 1 of 1
      • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
      Ask FixBot
    2. Blackberry Curve 9300 Screen Replacement: step 5, image 1 of 2 Blackberry Curve 9300 Screen Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
      Ask FixBot
    3. Blackberry Curve 9300 Screen Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to lift the bottom edge of the front cover.
      Ask FixBot
    4. Blackberry Curve 9300 Screen Replacement: step 7, image 1 of 1
      • Use your nails to unclip the sides of the frame from the phone.
      Ask FixBot
    5. Blackberry Curve 9300 Screen Replacement: step 8, image 1 of 1
      • Lift and remove the frame.
      Ask FixBot
    6. Blackberry Curve 9300 Screen Replacement: step 9, image 1 of 1
      • Lift and remove the keyboard.
      Ask FixBot
    1. Blackberry Curve 9300 Screen Replacement, Screen: step 10, image 1 of 1
      • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
      Ask FixBot
    2. Blackberry Curve 9300 Screen Replacement: step 11, image 1 of 1
      • Carefully pull the keyboard base up and away from the phone.
      • Disconnect the keyboard base from the phone completely.
      Ask FixBot
    3. Blackberry Curve 9300 Screen Replacement: step 12, image 1 of 3 Blackberry Curve 9300 Screen Replacement: step 12, image 2 of 3 Blackberry Curve 9300 Screen Replacement: step 12, image 3 of 3
      • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
      Ask FixBot
    4. Blackberry Curve 9300 Screen Replacement: step 13, image 1 of 2 Blackberry Curve 9300 Screen Replacement: step 13, image 2 of 2
      • Use a plastic opening tool to find the crease below the screen.
      • Insert where shown and use the tool to unclip the two sides of screen from body.
      • The opening tool goes approximately midway between the top and bottom edge of the screen.
      Ask FixBot
    5. Blackberry Curve 9300 Screen Replacement: step 14, image 1 of 2 Blackberry Curve 9300 Screen Replacement: step 14, image 2 of 2
      • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
      Ask FixBot
    6. Blackberry Curve 9300 Screen Replacement: step 15, image 1 of 3 Blackberry Curve 9300 Screen Replacement: step 15, image 2 of 3 Blackberry Curve 9300 Screen Replacement: step 15, image 3 of 3
      • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
      Ask FixBot
9 other people completed this guide.
Alek Squires
437 Reputation
2 Guides authored
Cal Poly, Team 14-7, Forte Fall 2013 Member of Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Members
60 Guides authored
1 Guide Comment
would appreciate new ldc part # and order info! - - !
Donald Burgo - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 93
All Time: 5,439
