Blackberry Curve 8330 LCD Panel Replacement
    1. Blackberry Curve 8330 LCD Panel Replacement, Remove Back Cover: step 1, image 1 of 1
      • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
      • Hold the phone with the back side facing you.
      • Press down on the silver tab towards the bottom end of the phone.
      • Carefully lift up the back casing to reveal the battery.
      Ask FixBot
    2. Blackberry Curve 8330 LCD Panel Replacement, Remove Battery: step 2, image 1 of 1
      • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
      • The phone should now look like this.
      Ask FixBot
    1. Blackberry Curve 8330 LCD Panel Replacement, Keyboard: step 3, image 1 of 1
      • Remove the two top screws using a T5 Torx screwdriver.
      Ask FixBot
    2. Blackberry Curve 8330 LCD Panel Replacement: step 4, image 1 of 2 Blackberry Curve 8330 LCD Panel Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
      • The cover will now pull off easily.
      Ask FixBot
    3. Blackberry Curve 8330 LCD Panel Replacement: step 5, image 1 of 2 Blackberry Curve 8330 LCD Panel Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to pry between the front and back cover.
      • Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
      • There are 5 securing clips on the front panel to disconnect.
      • Pry gently to prevent breaking the plastic clips when removing the front panel.
      • Once all the clips have been freed, the front cover will lift away from the phone.
      Ask FixBot
    4. Blackberry Curve 8330 LCD Panel Replacement: step 6, image 1 of 1
      • Lift the flexible keypad away from the device. It should come off easily.
      Ask FixBot
    5. Blackberry Curve 8330 LCD Panel Replacement: step 7, image 1 of 2 Blackberry Curve 8330 LCD Panel Replacement: step 7, image 2 of 2
      • Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
      • Lift the keyboard frame away from the device.
      • There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
      Ask FixBot
    1. Blackberry Curve 8330 LCD Panel Replacement, LCD Panel: step 8, image 1 of 2 Blackberry Curve 8330 LCD Panel Replacement, LCD Panel: step 8, image 2 of 2
      • Detach each side casing by pulling them off gently from the phone.
      Ask FixBot
    2. Blackberry Curve 8330 LCD Panel Replacement: step 9, image 1 of 1
      • Remove the back housing from the mother board.
      Ask FixBot
    3. Blackberry Curve 8330 LCD Panel Replacement: step 10, image 1 of 1
      • Unhook the screen frame from the small tab at the top of the motherboard.
      Ask FixBot
    4. Blackberry Curve 8330 LCD Panel Replacement: step 11, image 1 of 2 Blackberry Curve 8330 LCD Panel Replacement: step 11, image 2 of 2
      • Using a plastic opening tool, detach the connector on the LCD screen from the motherboard.
      • There may be some adhesive behind the LCD screen. If needed, pry the LCD screen away from the motherboard using the plastic opening tool.
      • Remove the LCD screen from the motherboard
      Ask FixBot
Joshua Ramos
65 Reputation
2 Guides authored
Cal Poly, Team 14-11, Forte Spring 2012 Member of Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 24
Past 30 Days: 42
All Time: 1,955
