Blackberry Curve 8320 Front Panel Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
91
All Time:
3,263
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The purpose of this guide is to provide instructions for the Blackberry Curve 8320 front panel replacement.
Specifically, this guide will show you how to:
  1. Remove the battery
  2. Remove the front cover
  3. Replace the front panel
To repair this device there are no specific skills required however, when removing parts and reassembling the device it is important to handle the device with care. This device is an older model phone and therefore it is essential to follow the instructions carefully in order to ensure the longevity of the device.
Tools
    1. Blackberry Curve 8320 Front Panel Replacement, Battery: step 1, image 1 of 2 Blackberry Curve 8320 Front Panel Replacement, Battery: step 1, image 2 of 2
      • Hold the phone with the back facing you.
      • Press the silver tab down and remove the cover.
      Ask FixBot
    2. Blackberry Curve 8320 Front Panel Replacement: step 2, image 1 of 1
      • Pull up on the top edge of the battery to remove it.
      Ask FixBot
    1. Blackberry Curve 8320 Front Panel Replacement, Front Panel: step 3, image 1 of 3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: step 3, image 2 of 3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: step 3, image 3 of 3
      • Use a plastic opening tool to gently pry the bottom cover loose.
      • Do not use excessive force at risk of damaging the antenna, which is under this casing.
      • Pull the cover from the front of the phone after the back is loose.
      Ask FixBot
    2. Blackberry Curve 8320 Front Panel Replacement: step 4, image 1 of 2 Blackberry Curve 8320 Front Panel Replacement: step 4, image 2 of 2
      • Remove the two top screws with a T5 Torx screwdriver.
      • The screws are 8mm long.
      Ask FixBot
    3. Blackberry Curve 8320 Front Panel Replacement: step 5, image 1 of 2 Blackberry Curve 8320 Front Panel Replacement: step 5, image 2 of 2
      • Gently pry off the side casings from the top.
      • The side casings cannot be fully removed yet because they are screwed on at the bottom.
      • You will not need to remove the sides on the bottom.
      Ask FixBot
    4. Blackberry Curve 8320 Front Panel Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
      • There are six securing clips total.
      Ask FixBot
    5. Blackberry Curve 8320 Front Panel Replacement: step 7, image 1 of 1
      • Carefully remove the front panel.
      • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
      Ask FixBot
Christopher Aiello
104 Reputation
5 Guides authored
Cal Poly, Team 3-6, Regan Fall 2011 Member of Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 91
All Time: 3,263
