Blackberry Classic Battery Replacement
    1. Blackberry Classic Battery Replacement, Remove SIM and SD Tray: step 1, image 1 of 3 Blackberry Classic Battery Replacement, Remove SIM and SD Tray: step 1, image 2 of 3 Blackberry Classic Battery Replacement, Remove SIM and SD Tray: step 1, image 3 of 3
      • Use a SIM tool to remove the SIM and micro SD card trays.
      Ask FixBot
    2. Blackberry Classic Battery Replacement, Remove Battery Cover: step 2, image 1 of 3 Blackberry Classic Battery Replacement, Remove Battery Cover: step 2, image 2 of 3 Blackberry Classic Battery Replacement, Remove Battery Cover: step 2, image 3 of 3
      • Use a Jimmy to pry between the midframe and back cover. Wiggle back and forward until the first clip releases.
      • Switch to a plastic spudger and continue gently prying along the edge of the back cover to release the clips.
      • Once all the clips are released around the edge of the cover, you will need to use a guitar pick to cut through adhesive on the top and bottom of the cover. Take care not to cut through the battery ribbon cable. The top adhesive is behind the glass feature on the back cover. You may need to apply some heat.
      Ask FixBot
    3. Blackberry Classic Battery Replacement, Disconnect Battery: step 3, image 1 of 3 Blackberry Classic Battery Replacement, Disconnect Battery: step 3, image 2 of 3 Blackberry Classic Battery Replacement, Disconnect Battery: step 3, image 3 of 3
      • One T5 (lower) and one PH00 (upper) screwdriver heads are needed to remove the battery's connector shield.
      • Then use a spudger to pry the battery's connector from the motherboard. Be sure to pry with even pressure.
      Ask FixBot
    4. Blackberry Classic Battery Replacement, Remove Battery: step 4, image 1 of 3 Blackberry Classic Battery Replacement, Remove Battery: step 4, image 2 of 3 Blackberry Classic Battery Replacement, Remove Battery: step 4, image 3 of 3
      • Use extreme caution when removing the battery. It is directly against the motherboard, and piercing the battery could corrode other components. It could also catch flame.
      • Take off the battery shield, and use a scalpel or other flat tool to remove the foam on the connector. Place these onto new battery.
      • Carefully apply some low heat to the stickers covering the battery and gently peel them off. The white sticker is connected to adhesive under the battery.
      • Gently pry up on the edges of the battery so that the adhesive will come out more easily. Take great care not to pierce the black "skin" on the battery.
      • Slowly start pulling the adhesive tab out, regripping close to the battery as it starts to come out.
      Ask FixBot
    5. Blackberry Classic Battery Replacement, Remove Battery Cont'd: step 5, image 1 of 3 Blackberry Classic Battery Replacement, Remove Battery Cont'd: step 5, image 2 of 3 Blackberry Classic Battery Replacement, Remove Battery Cont'd: step 5, image 3 of 3
      • Be sure to add adhesive to the new battery, and replace the foam on the connector.
      Ask FixBot
    6. Blackberry Classic Battery Replacement: step 6, image 1 of 1
      • Adhesive is best around outer edges.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Remember to replace the foam pad on the connector.
18 other people completed this guide.
Jessica Pickering
624 Reputation
1 Guide authored
Circuits Cell Shop Member of Circuits Cell Shop
Business
1 Member
12 Guides authored
8 Guide Comments
thank you so much
ttlchan - Reply Share
Glad it helped!
Jessica Pickering - Reply Share
Success! Nerve racking for an amateur and I could not have done it without your guidance.
Thank you.
Ken Wright - Reply Share
So happy to be of help!
My BB is going to have a 2nd life. Unbelievably irresponsible to glue everything together.
Thx Jessica for this great guide. It worked perfectly and in a spell.
Erwin Silberstein - Reply Share
Past 24 Hours: 11
Past 7 Days: 62
Past 30 Days: 240
All Time: 33,154
