Blackberry Classic digitizer Replacement
    1. Blackberry Classic  digitizer Replacement, Digitizer assembly: step 1, image 1 of 1
      • Start by removing the back cover.
      • It's glued on the top and at the bottom. Use an isesamo and gentle force to remove it
      Ask FixBot
    2. Blackberry Classic  digitizer Replacement: step 2, image 1 of 1
      • Like many other blackberry models, lift out the small plastic edge at the bottom of the keyboard
      • This will reveal two torx screws to remove
      Ask FixBot
    3. Blackberry Classic  digitizer Replacement: step 3, image 1 of 1
      • Turn the blackberry around and remove all torx screws
      • Separate the battery screws as they are different
      • Watch out for the 00 Philips screw on the top left corner
      • Remove the plastic mid-frame
      Ask FixBot
    4. Blackberry Classic  digitizer Replacement: step 4, image 1 of 1
      • The battery is held firmly by glue (or space putty?)
      • That 4$ card proved its utility
      • Be careful when removing the adhesive not to pry the small connectors at the base of the board.
      Ask FixBot
    5. Blackberry Classic  digitizer Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • The board is clipped and lightly glued. Use tweezers to lift the retention clips under the board to release it.
      Ask FixBot
    6. Blackberry Classic  digitizer Replacement: step 6, image 1 of 1
      • Remove the micro usb connector, the audio jack and the 3 ph000 screws on the board.
      • This will allow you to push out the metal mid-frame
      Ask FixBot
    7. Blackberry Classic  digitizer Replacement: step 7, image 1 of 1
      • Once screws are all out, gently lift the broken digitizer. Make sure to lift between the display assembly and the black border.
      • Remove any remaining shattered glass from the display frame before reassembling.
      • Reassemble in reverse order
      Ask FixBot
23 other people completed this guide.
coutureg
885 Reputation
1 Guide authored
Techno-sos Member of Techno-sos
Business
1 Member
12 Guides authored
9 Guide Comments
If I’m just switching boards, is it even necessary to remove the battery? Can’t I just switch the boards with the batteries still attached to their respective boards? I just don’t see the point of removing the battery unless you are replacing it.
gary - Reply Share
If you are replacing the board and the battery, and can reach the retention clips under the board to lift the board out of the case, I guess it could be possible to replace both parts without separating them.
coutureg - Reply Share
So I can confirm that you do not need to remove the battery to switch the boards. You can leave it stuck to the board.
https://imgur.com/a/FtY09en
gary - Reply Share
Interesting, thanks for the update ! Cheers !
You are welcome! Thanks for the great writeup coutureg
gary - Reply Share
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 103
All Time: 18,133
