Blackberry Bold 9900 Power/Volume Button Replacement
  1. Blackberry Bold 9900 Power/Volume Button Replacement, Battery: step 1, image 1 of 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
    Ask FixBot
  2. Blackberry Bold 9900 Power/Volume Button Replacement: step 2, image 1 of 1
    • Lift the edge of battery with the green stripe upward to remove battery.
    Ask FixBot
  3. Blackberry Bold 9900 Power/Volume Button Replacement, Mini-SIM removal: step 3, image 1 of 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
    Ask FixBot
  4. Blackberry Bold 9900 Power/Volume Button Replacement, MicroSD card: step 4, image 1 of 2 Blackberry Bold 9900 Power/Volume Button Replacement, MicroSD card: step 4, image 2 of 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
    Ask FixBot
  5. Blackberry Bold 9900 Power/Volume Button Replacement, Keyboard: step 5, image 1 of 2 Blackberry Bold 9900 Power/Volume Button Replacement, Keyboard: step 5, image 2 of 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
    Ask FixBot
  6. Blackberry Bold 9900 Power/Volume Button Replacement: step 6, image 1 of 2 Blackberry Bold 9900 Power/Volume Button Replacement: step 6, image 2 of 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
    Ask FixBot
  7. Blackberry Bold 9900 Power/Volume Button Replacement: step 7, image 1 of 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
    Ask FixBot
  8. Blackberry Bold 9900 Power/Volume Button Replacement: step 8, image 1 of 2 Blackberry Bold 9900 Power/Volume Button Replacement: step 8, image 2 of 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
    Ask FixBot
  9. Blackberry Bold 9900 Power/Volume Button Replacement, Back Case: step 9, image 1 of 1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
    Ask FixBot
  10. Blackberry Bold 9900 Power/Volume Button Replacement: step 10, image 1 of 1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
    Ask FixBot
  11. Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: step 11, image 1 of 3 Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: step 11, image 2 of 3 Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: step 11, image 3 of 3
    • Use the black nylon spudger to pop the press fit connector up from the lower left corner of the motherboard.
    Ask FixBot
  12. Blackberry Bold 9900 Power/Volume Button Replacement: step 12, image 1 of 1
    • Lift the midframe, which contains the power/volume buttons, off of the motherboard and screen.
    Ask FixBot
Sarah Westberg
40,940 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,230 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 66
All Time: 1,965
