Blackberry Bold 9000 Volume Toggle Replacement
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: step 1, image 1 of 1
    • Place your Blackberry facedown in front of you.
    Ask FixBot
  2. Blackberry Bold 9000 Volume Toggle Replacement: step 2, image 1 of 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
    Ask FixBot
  3. Blackberry Bold 9000 Volume Toggle Replacement: step 3, image 1 of 1
    • From the top, use your fingernail to lift the battery out.
    Ask FixBot
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: step 4, image 1 of 1
    • Remove the SIM card.
    Ask FixBot
  5. Blackberry Bold 9000 Volume Toggle Replacement: step 5, image 1 of 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
    Ask FixBot
  6. Blackberry Bold 9000 Volume Toggle Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to remove the rear case.
    Ask FixBot
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: step 7, image 1 of 1
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
    Ask FixBot
  8. Blackberry Bold 9000 Volume Toggle Replacement: step 8, image 1 of 1
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
    Ask FixBot
  9. Blackberry Bold 9000 Volume Toggle Replacement: step 9, image 1 of 1
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
    Ask FixBot
2 other people completed this guide.
Kelly
590 Reputation
6 Guides authored
Cal Poly, Team 8-17, Maness Winter 2012 Member of Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 2,779
