Blackberry Bold 9000 LCD Screen Replacement
  1. Blackberry Bold 9000 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Place your Blackberry facedown in front of you.
    Ask FixBot
  2. Blackberry Bold 9000 LCD Screen Replacement: step 2, image 1 of 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
    Ask FixBot
  3. Blackberry Bold 9000 LCD Screen Replacement: step 3, image 1 of 1
    • From the top, use your fingernail to lift the battery out.
    Ask FixBot
  4. Blackberry Bold 9000 LCD Screen Replacement, Rear Case: step 4, image 1 of 1
    • Remove the SIM card.
    Ask FixBot
  5. Blackberry Bold 9000 LCD Screen Replacement: step 5, image 1 of 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
    Ask FixBot
  6. Blackberry Bold 9000 LCD Screen Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to remove the rear case.
    Ask FixBot
  7. Blackberry Bold 9000 LCD Screen Replacement, LCD Screen: step 7, image 1 of 1
    • With the same plastic opening tool, lift the motherboard up and out.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
    Ask FixBot
  8. Blackberry Bold 9000 LCD Screen Replacement: step 8, image 1 of 1
    • Using a spudger, lift the ribbon band in the upper right-hand corner up and away from the motherboard assembly until it disconnects.
    Ask FixBot
  9. Blackberry Bold 9000 LCD Screen Replacement: step 9, image 1 of 1
    • Turn the motherboard assembly over.
    • Starting at the lower corners of the screen, begin to lift the screen away from the motherboard using the spudger.
    • Do this step very slowly to avoid breaking the screen or the motherboard. The backing will eventually separate.
    • Remove the plastic bit that hides the speaker grill - it is stuck with double-sided tape.
    • With a thin blade/pin, ease the speaker grill and the metal plate away from the old lcd screen.
    Ask FixBot
8 other people completed this guide.
Kelly
590 Reputation
6 Guides authored
Cal Poly, Team 8-17, Maness Winter 2012 Member of Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 7,967
