Blackberry 8700c Battery Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
85
All Time:
3,467
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
In this installation guide, you will remove a damaged battery and install a new one in your Blackberry 8700c.
    1. Blackberry 8700c Battery Replacement, Battery: step 1, image 1 of 3 Blackberry 8700c Battery Replacement, Battery: step 1, image 2 of 3 Blackberry 8700c Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the back cover by pushing the button near the bottom of the phone and sliding the cover off.
      Ask FixBot
    2. Blackberry 8700c Battery Replacement: step 2, image 1 of 2 Blackberry 8700c Battery Replacement: step 2, image 2 of 2
      • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
      • If you are not installing a new battery, move on to the next step. If you are installing a new battery, read on.
      • Install the new battery by first placing the bottom end of the battery in the phone and then pushing the battery into place.
      Ask FixBot
To reassemble your Blackberry 8700c, follow these instructions in reverse order.
k3nt
42 Reputation
4 Guides authored
Cal Poly, Team 18-4, Maness Fall 2009 Member of Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 85
All Time: 3,467
